going to 2 barrel?
Old Feb 5, 2004 | 09:33 AM
montster's Avatar
montster
Question going to 2 barrel?
can any body tell the best place to find a 2100 ie year make and model of a donor truck or car. I like to scrounge in the wreckers and would like to put a 2 barrel on my 83 bronco I-6 also does any body know what the addapter plate looks like I would like to fab one and pics would be great. it is too cold up here to wheel so projects I can carry inside are about it. I thought maybe use a block of alluminum scribe the intake after grinding on one side and the bottom of the carb on the other side then grind it out to meet.(ya its a lot of grinding) but I need a project and it would be cool to do.
thanks
Old Feb 5, 2004 | 05:01 PM
Stroblite400's Avatar
Stroblite400
The 2100 and 2150 motorcraft carbs have always been crappers. But everyone has their own oppinion. But if you are looking for a donor try a 78 or 79 f150, they usually have the 400's with the two barrel. i would just go with a aftermarket two barrel or even buy the 4barrel intake out of jegs. It says itll give you 50 more horses. But you would have to get an aftermarket 4 barrel as well.
Old Feb 6, 2004 | 09:00 AM
Oscar Meier's Avatar
Oscar Meier
The 2150 Motorcraft 2V is a great carb. It's one of the few you can actually tune to a 300 and get very good results.
Strobe is correct the 2150 is on all the 351M & 400 it's the only carb Ford used on that engine. It can be either a car or truck to get the 2150 2V.
Look at Bubba's M-Block web page for plenty of 2150 info.
You can also find rebuilt 2150's on E-bay for about $100. One tip if you are going to put a 2150 on to a stock 300, you'll need to jet it down to about a #50 main jet.
Adaptors are available from Clifford.
Good luck
Oscar
