x-pipe
Old Feb 5, 2004 | 02:23 AM
TN89F-150's Avatar
TN89F-150
x-pipe
Hey all,
This may sound a little stupid, but does anyone know where to obtain an x-pipe or something to replace the factory crossover pipe between the exhaust manifolds and the cat? On my T-birds I have used BBK Headers,Mustang x-pipes and Flomaster cat-back systems. I found that Flowmaster makes a cat-back for my truck, but I am still at a loss for a source for the headers (ceramic coated) and x-pipe.
Thanks in Advance.
Old Feb 5, 2004 | 07:25 AM
ATC_250SX's Avatar
ATC_250SX
a good muffler shop can make you a CROSSOVER pipe, if your doing a cat back its gonna want the pipe where it is now so youd need a crossover not an x pipe, and if you put shorttys on your truck you can retain the stock crossover and get prettymuch the same effects.
Old Feb 5, 2004 | 11:28 PM
tripndrag's Avatar
tripndrag
Bassani makes an offroad version that has O2 bung and EGR tube connection for 260 bucks. It is the only one I know of except for a stock replacement. My buddy just ordered one and it should be here soon. We both put headers on our trucks and the stock Ypipe does not fit any longer. I had mine fixed at a shop to kind of fit better but I hope the Bassani will have bigger collector tubes to fit aftermarket headers better.
Old Feb 12, 2004 | 07:34 PM
TN89F-150's Avatar
TN89F-150
tripndrag,
When you say headers, are you refering to long tube, or the shorties like gibson sells? I am looking for shorties that are ceramic coated. I have used BBK's on my t-birds with excellent results, but haven't found a source for the pickup yet. It is a 5.5l 342 stroker motor. I was going to go with American thunder, but it looks like they don't make "true" duals like I thought only from the muffler back are duals. Any source would be appreciated.
Old Feb 12, 2004 | 11:27 PM
94F150-408's Avatar
94F150-408
Bassani makes headers for the Ford trucks, they have equal length shorties made for the Y pipe they sell. You can also go with a JBA Firecone header. I've had both and both that I have are ceramic coated. Check out their web sites. They are both high quality headers.
Old Feb 13, 2004 | 09:04 PM
tripndrag's Avatar
tripndrag
I am talking about shorties. The Gibsons, BBK's and Bassani's will not work with the stock Y-pipe. Buy the Bassani Y-pipe, they have a version with cats and a version without. My buddy just got his non-cat version and it is awesome! It has on 02 bung and tube for the egr tube to connect to. The flanges are 3 inch so they fit on those 3 headers brands of headers perfect. The BBK's are the best for the dollar. The Gibsons are pretty small, the BBK's are 1 5/8's and very nice. The Gibsons have splits on the ears where the Y-pipe bolts up and the tubes are smaller. You can get a torque wrench on the header bolts though, you can only get a wrench on the BBK bolts because the tubes are so large. The Bassani's are in a class of their own and are twice the cost of the others. Edelbrock just started making truck headers, the pictures look nice but I have not seen a pair in person. Use the 1" long stage 8 bolts, don't put the locks on till you have run it a few times and re-tightened the bolts. I tried some Earl's Performance gaskets and they suck. I just installed some Persey's gaskets on a 97 Mustang and they worked perfect so I may go with a set of those.
Old Feb 14, 2004 | 12:22 PM
TN89F-150's Avatar
TN89F-150
Thanks for the info TripNDrag, Do you know if BBK also makes a y-pipe? I have had great luck with the BBK product line in the past. I was not able to find a reference to their Truck headers though, so I guess I'll have to research a bit more. I definitely want them ceramic coated, as they seem to last much, much longer.
Old Feb 14, 2004 | 04:29 PM
tripndrag's Avatar
tripndrag
I called them and they do not have a Y-pipe. Bassani is the only company out of BBK, JBA, Dynomax, Gibson and hooker that I have contacted that make one. I didn't see the ceramic option when I got my truck headers. Mine have discolored a little bit but they look great still. I am sure the Bassani's are much better quality, the BBK's were very dirty around the welds. I wanted to grind them smooth but I didn't want to weaken them so I just left them alone. For 250 bucks I am very happy. I have heard great things about the Summit truck headers but I have never seen them, they were a little less than the BBK's but I have also had great luck with BBK so I stuck with them on the pickup. I have pictures of the Bassani Y-pipe, if you would like me to send them to you just give me an email address.
Old Feb 14, 2004 | 10:30 PM
TN89F-150's Avatar
TN89F-150
TripNDrag,
It is my understanding that we can't post e-mail addresses here, but if you send it to my username at earthlink a .net company, I am sure to receive it. Thanks.
Old Feb 18, 2004 | 11:37 AM
tripndrag's Avatar
tripndrag
I just sent them to T89F-150.
Old Feb 18, 2004 | 05:42 PM
tripndrag's Avatar
tripndrag
The mail address didn't work, it was all returned.
Old Feb 21, 2004 | 01:00 PM
TN89F-150's Avatar
TN89F-150
TripNDrag,
It's TN89F-150, please note the missing "N" I know the add worrks since I got the notification that you sent a reply...
Old Feb 21, 2004 | 02:32 PM
tripndrag's Avatar
tripndrag
I don't think I had it wrong in the email, I think I just typed it wrong in the post!!! I just tried sending them again so maybe it will work this time.
