Decode these codes ??
Old Feb 4, 2004 | 09:42 PM
GWTarpon's Avatar
GWTarpon
'90 300 I-6 w/ E4OD transmission
I have the following codes, any ideas on what they mean ??
No KoEo codes
Continuous codes are:
49- SPOUT signal default to 10 degreees BTDC
or
1-2 shift error [E4OD ]
59- 2-3 shift error [E4OD]
or
Low Speed fuel pump failure
62- Converter clutch error [E4OD]
Since I have the E4OD transmisssion and all three codes indicate a problem with transmission, I suspect my problem has something to do with the transmission [duh !!!] Problem is I do not feel any problems with the transmission. I was checking codes because of slightly rough idle, tough to start/stalls cold, a bit of hesitation on acceleration. Any ideas, gents ??
Haven't checked running codes yet, too cold outside.
Old Feb 5, 2004 | 11:27 AM
jimandmandy's Avatar
jimandmandy
Look at those codes and symtoms. Low Speed fuel pump failure matches your starting/stalling idle and hesitation pretty well. Your timing is also in question and that can cause hesitation. Check the timing and fuel pressure.
Jim
