351w oil pressure problems
Old Feb 4, 2004 | 09:36 PM
blue oval blues's Avatar
blue oval blues
Unhappy 351w oil pressure problems
i have a 1992 f-150 called old blue. the old girls oil presure just dropped out one day after our drive home frome work. Then after checking her vitals with a mechanical guage and performing a 3-day oil pump byopsee she dropped on me again this morning. presure is up while driving but flatlined at idle. I also gave her a small dose of sending unit asprin with no response. please help me I LOVE my OLD BLUE.
Old Feb 5, 2004 | 12:00 AM
Superdave's Avatar
Superdave
blue oval blues
High mileage enigne?
I am assuming you mean you changed the oil pump and verified the low oil pressure with a mechanical gauge?
More than likely the bearings in the bottom end are worn out.
Old Feb 5, 2004 | 03:45 PM
Blurry94's Avatar
Blurry94
I have this problem with mine. So I use 10w40 motor oil in the winter and 20w50 in the summer, and the pressure stays solid at all RPM's. I need to pull the motor for a rebuild, but I have to finish the race truck first before I start another project.
Old Feb 5, 2004 | 08:18 PM
MustangGT221's Avatar
MustangGT221
The oil pressure should be between 40-60 psi at idle on a warm engine. IF the oil pressure comes up to 40-60 when the engine is cold, but drops down when it warms up (at idle still) than it's the engines bearings that are worn and the engine needs a rebuild. When the engine warms up the oil thins out so it creates spaces and gaps which drop oil pressure.
Old Feb 6, 2004 | 05:51 PM
Geffy95x's Avatar
Geffy95x
Did you say you gave the sender aspirin ?.
Well if you didn't replace the sender i would make that my next move before a rebuild, especially if the pressure just dropped out on you ,bearings wear out a little slower than that .
Unless you had no oil at all
Old Feb 6, 2004 | 11:14 PM
Egor's Avatar
Egor
In the 90's the oil sender is just a switch. At about 8 lbs pressure it will read half way on the guage, less than that it will drop to nothing. Mine started doing this overnight and I checked it with a mechanical gauge, had around 40 lbs on startup and dropped to less than 10 when hot. About a week later it started knocking. Sorry about the bad news.
radco99
May 4, 2011 09:58 AM
ontario ford guy
Oct 19, 2005 06:28 PM
johnl9457
Aerostar
Mar 6, 2005 09:56 PM
fiittllc
May 3, 2004 03:10 PM
tribalboy
Oct 31, 2002 03:20 PM
