Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Plastic air lines
Old Feb 4, 2004 | 08:31 PM
Tom41ks's Avatar
Tom41ks
Plastic air lines
My friends ,I need help convencing my boss's boss that PVC is not air line material.
Old Feb 4, 2004 | 08:56 PM
jbullfrog's Avatar
jbullfrog
Talking Your boss is right.
I have worked in many shops with PVC air lines. It's cheap and doesn't swet like iron. Most shops use 3/4 PVC for the runs to 3/8 hoses and 1" PVC for 1/2" hoses. As long as PVC is anchored properly and glued right it works great.
Old Feb 4, 2004 | 09:21 PM
Tom41ks's Avatar
Tom41ks
You arn't helping me at all.There is some reason that pvc can't be used as air line.What is it?
Old Feb 4, 2004 | 09:22 PM
otto's Avatar
otto
we do all our air lines in schedule 40 black pipe, we buy it in 20' lengths and have a rigid power threader
Shatterable PVC is no good in a shop enviroment, IMHO
My hone has a 20' long 4" diameter crossover pipe where the honing oil flows between drains from the table, well they did it out of PVC on the cheap, somebody dropped something on it, pipe broke, 100 gallons of oil rushes out of the 4".............next pipe piece was steel with welded flanges
Old Feb 4, 2004 | 09:30 PM
Ford79's Avatar
Ford79
Read this thread, there are many good points in there. Maybe print it off and give it to your boss too.
http://www.fordtrucks.com/forums/sho...threadid=98203
Old Feb 4, 2004 | 10:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
PVC is illegal to use for air lines, Check with your OSHA inspector. Check with the PVC pipe manufacturers!
DO NOT USE PVC FOR AIR LINES!!!
jbullfrog is DEAD wrong!
Read the other threads here for more information, all you had to do is search.
Old Feb 5, 2004 | 10:55 AM
79Lariat's Avatar
79Lariat
PVC is NOT for airlines
Eric,
This topic keeps coming up time after time. Would it be possible in the interest of saving time and lives, to post the threads that we have gone to such lengths in as "stickies"? Maybe that would stop this from coming up again and again.
Old Feb 5, 2004 | 11:02 AM
Phillippio's Avatar
Phillippio
I once worked in a shop with all PVC airlines. They worked great if you didn't touch them. When you did touch them, they would blow out. They finally had to redo the whole system. PVC just can't handle more than about 80 psi. I think that is the standard schedule 40 rating anyway.
I agree with Torque1st "Do not use PVC for Air Lines".
Why not do it right the first time with steel?
Old Feb 5, 2004 | 11:48 AM
Big Orn's Avatar
Big Orn
Ditto! It is not the fact that it will not hold the pressure it's pipe failure (bumping = exploding)!!!
It is not OSHA approved!
On edit: Here's a link for one: http://www.woodcentral.com/bparticles/airpiping.shtml
Old Feb 5, 2004 | 12:06 PM
jbullfrog's Avatar
jbullfrog
Unhappy Let me clarify:
I do not use PVC in my shop I have worked in shops that use it.
Please don't hold the mistakes of previous employers against me. I don't work there anymore because of safety issues like this.
Old Feb 5, 2004 | 05:11 PM
Torque1st's Avatar
Torque1st
Posting Legend
jbullfrog- Then why did you recommend it if you knew better???
I have started a FAQ section above. It was long overdue. Check it out and let me know if you have any additions or comments. -Thanks 79Lariat for the suggestion!
Old Feb 6, 2004 | 05:46 PM
Grashopr's Avatar
Grashopr
PVC used as a spanner to get to the outlets is a bad idea at every turn....the joints are glued together, and the more air you push through the system, the more heat is built up by the mass movement.....hte heat can make the plastic brittle (subject to failure upon bumping or even touching) and it causes the glue to break down as it has very VERY low viscocity, which causes the joints to be a timebomb waiting to fly apart.
**I** wouldn't use it around people that I liked....but in a shop environment, depends on how much you like your coworkers.
The 'hopper
Old Feb 6, 2004 | 06:52 PM
Torque1st's Avatar
Torque1st
Posting Legend
It isn't the heat either, it is just the failure mode of the material. It fails in a brittle manner and explodes. The glue is not a glue per se, it is a solvent that fuses the two surfaces together. That is why you are supposed to mix the materials by twisting the joint while pushing it together.
PVC should never be used anywhere for compressed gas service.
Old Feb 9, 2004 | 09:20 AM
Aftrmidnite's Avatar
Aftrmidnite
Why don't you use "L" copper with Brazed joints? It won't rust, is light weight, and is easy & cheap to insulate. You can get all the fittings, pipe, hangers, and braze rods at a refrigeration supply house. Just remember we measure by outside diameter. So 1/2" is 5/8"; 3/4" is 7/8"; 1" is 1&1/8". Make sure you sweat the joint not pile the brazing rod up at the connection. The braze should run back into the joint, you do this by heating the bulge in the fitting, its like soldering only hotter. Cherry red is too hot, so stay just under this point. If you quinch copper it gets soft, if you walk away and let it cool its hard, unless it was over heated. So you should quinch 90s and let thread connections cool gradually. Avoid 45s as they tend to crack.
rrbb
5.0L Coyote
May 24, 2014 07:33 PM
Oaktree
General Automotive Discussion
Apr 1, 2008 07:42 PM
deanjet
May 12, 2007 10:35 PM
ChuckE
1978 - 1996 Big Bronco
Dec 28, 2004 12:24 AM
Tadashi
May 25, 2004 06:15 PM
