351m problem
Old Feb 4, 2004 | 07:04 PM
RichardMaerz69's Avatar
RichardMaerz69
351m cam
hay all,I have a 351m that doesn't seem to want to stay timed changed my gears and chain about a year ago and it run fine,until now it's starting to sputter until my rpms go up and shifts its an automatic.runs noticeably rough at idle could it be time to replace my cam,or do I have another problem.PS the truck has 172+ miles on the original 81 351m any help would be appreciated thanx.
Old Feb 5, 2004 | 01:00 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check your distributor advance mechanism.
Old Feb 5, 2004 | 06:00 AM
RichardMaerz69
thanx for reply,now can you tell me what to look for and how to set it I'm not to good with the internal workins of a distributor.
Old Feb 5, 2004 | 07:17 AM
Torque1st's Avatar
Torque1st
Posting Legend
Do you have a repair manual? If you do there is all sorts of info in them with nice exploded drawings etc. If you don't feel up to examining the distributor innards a good old time auto shop mechanic can get the job done.
Old Feb 5, 2004 | 09:53 AM
beartracks's Avatar
beartracks
What exactly do you mean by "wont stay timed"? Does the timing retard itself? i.e. do you have to keep increasing it?
Old Feb 5, 2004 | 10:03 AM
74 F100 351m's Avatar
74 F100 351m
Check to make shur that the pick coil does not hit the sprag, if the bushing is lose on the plate that it sits on it will hit and couse if to miss on that cyclender. And it is not always the some one. At a idle it will do this, but at 1000 rpm the sprag ask like a fan and blowes it back so it does not hit. I have 2 mouths of heir pulling before changing the dis. .
Old Feb 5, 2004 | 05:37 PM
RichardMaerz69
found out why it wouldnt stay timedthe bolt kept vibrating loose beacause the airconditioning pump is in the way had to take it all apart to get it tight enuff,but stil; having same problem,I'm going to try doing what you guys metioned above thanx for the help
Old Feb 6, 2004 | 07:38 PM
RichardMaerz69
engine seems to be draging like when the timing isn't advanced enuff .thought it was just me but it did this just beafore I changed the the timing chain a year ago,and then it run fine for a year ,didnt expect this prblem to pop up again is this still the dizzy ,I'm going crazy, i've been playing with this engine for over three years ,it runs good for a few months and then it @#$# up and I think this engine is tired and is need of some searious mods to wake it up.
