Sponsored by: Auxito
2003 F-150 Starting Problems
Old Feb 4, 2004 | 06:02 PM
jnadank's Avatar
jnadank
A friend of mine has a 03 F-150 5.4 V8 and is having troulbe starting his vehilce. It seams that when he turns the ignition over it cranks but it won't turn over. He described it as cutting out when he tries to start it. It doesn't happen all the time and outside temperature doesn't appear to be a factor. He has taken the vehicle into the local Ford dealership but they can't find the problem. They have checked the battery, starter, alternator, computer and also done diagnostic check and have found nothing wrong. Any suggestions would be appreciated.
Old Feb 4, 2004 | 09:11 PM
Racerguy's Avatar
Racerguy
Hi jnadank and welcome to FTE
Has he ever tried pressing the throttle pedal a bit when he's cranking it to see if that helps make it start? He could have a bad IAC which can cause a hard start.
Old Feb 4, 2004 | 10:38 PM
jnadank's Avatar
jnadank
What is an IAC? It sounds more like something is cutting out or disconnecting when he tries starting it as opposed to starting hard.
FordJunky1289
13
Jun 29, 2015 04:30 PM
blackshine007
Jun 8, 2014 07:13 AM
kedwinh
Jan 14, 2012 02:29 PM
mxhowes1
15
Jun 25, 2010 04:59 PM
Beast12
42
May 17, 2004 02:58 PM
