rear end indetification
Old Feb 4, 2004 | 02:43 PM
Dels86's Avatar
Dels86
Cool rear end indetification
need help indentifing my rear end, the tag on it says
v106B
5510 2 6F10
the door sticker also says axle- 29
chiltons isn't any help in this.
Old Feb 4, 2004 | 07:31 PM
oldhalftons's Avatar
oldhalftons
this might help
http://www.onandoffroad4wheeldrive.com/axle_pics.htm
Old Feb 4, 2004 | 10:00 PM
GypsyR's Avatar
GypsyR
You might look at that tag again. I believe you missed one.
I bet if you look right where the bolt goes through the tag you'll see part of a "3". Thay would make the second line read:
35510 2 6F10
A 3.55 ratio 10.25" rear end. If it's a "full floater" rear end, then you'll have hubs protruding about 3 inches from the brake drum. If it's a "semi floater" then the axle hubs end about flush with the drum just like all F150s and almost all rear wheel drive cars do.
That should be enough info for you to buy parts or whatever you are trying to do.
ShawnTJ
Sep 9, 2014 07:12 PM
HoustonGuy
Jan 22, 2013 07:32 AM
adam.hilberath
Nov 10, 2012 05:29 PM
andyman91
Feb 3, 2010 05:53 PM
1982fordf100
Nov 16, 2003 10:40 AM
