Which 302s will work
Old Feb 4, 2004 | 02:18 PM
geokel1014's Avatar
geokel1014
Was wondering what year 302 block will match a 1991 F150 302. I have read on the forum that there is a certain year that the F150 302 started with a knock sensor. Did cars also have this? I was thinking of buying a Crown Vic or Gran Marquis in the 88-90 range for $250-$400 and then building off the motor. Looked in junk yards but the motors are already out of the vehicle and don't know if the motor is runnig clean and smooth. I was planning on changing the cam to one that will run well with speed density and if can find will upgrade to GT40 heads. Any help or ideas will be appreciated. Thanks
Old Feb 4, 2004 | 05:31 PM
daerhldgs2's Avatar
daerhldgs2
the newer car blocks were roller especially the h.o. mustangs. Explorers got the gt40 heads after I believe 96 as did some of the trucks, You can use a regular cam in a roller block which Ford started with in 85.
Old Feb 7, 2004 | 10:30 AM
geokel1014's Avatar
geokel1014
Thanks for the info so far. Was hoping someone else had tried this and could give more insight. I have good mechanical ability, but my knowledge base is not very deep.
BigRobK
19
Dec 9, 2015 05:44 AM
Wildbill3406
Aug 20, 2015 05:04 PM
tweakerford
Mar 7, 2015 04:52 PM
nvytch
27
Oct 8, 2014 12:59 PM
Jrock909
Jun 23, 2002 12:05 AM
