? for Abendx & Chadrock
[updated:LAST EDITED ON 22-Apr-02 AT 11:29 AM (EST)]Hey guys what is the max tire pressure your tires say on them, and what pressure are you actually running in them? my 36" tsls say max 65lbs but that sounds like alot of air and I would assume it would ride rough at that pressure?
thanks guys you have both helped me alot on this lift and tire stuff
[updated:LAST EDITED ON 23-Apr-02 AT 01:20 AM (EST)]I run more pressure in the front because the front is heavier. The rear is lighter so it doesn't need the same pressure to get even wear across the tread. If I ran the same pressure in the rear as the front, the ride would be stiffer than it needs to be in the rear.
