Sponsored by: Auxito
Bad Clutch
Old Feb 4, 2004 | 08:41 AM
lynkje08's Avatar
lynkje08
Bad Clutch
I was wondering if anyone will help me out with a rather vague question. I own a 1997 F-150 with 102,000 miles. On a very cold MN morning, I awoke to a dead battery. After "jump starting" the battery I realized I couldnt get my truck into gear.
I can put in in gear when the engine is off and and drive around town in 1st gear, but am not able to change gears while engine is running.
Did I snap the clutch cable?
Does anyone have any ideas to what my problem is and what needs to be fixed?
How much should this cost to fix roughly?
Any info would be appreciated, would like to get this truck in today to get a look.
Thanks Ford Peeps
------New Member
Old Feb 4, 2004 | 08:49 PM
Racerguy's Avatar
Racerguy
Hi lynkje08 and welcome to the forum
Your clutch doesnt have a cable, it is hydraulicly operated.
Does the pedal push in like normal?
Old Feb 4, 2004 | 09:48 PM
LxMan1's Avatar
LxMan1
Try pumping the clutch pedal a couple of times and see if it will go into gear. Check the fluid in the clutch master cylinder
Old Feb 5, 2004 | 01:24 PM
lynkje08's Avatar
lynkje08
Ive tried pumping the clutch but to luck.
The clutch feels much looser than normal with no resistance until it is pressed half way to the floor.
Old Feb 5, 2004 | 08:00 PM
Racerguy's Avatar
Racerguy
I'd bet you have a leaking clutch slave cylinder
See if the fluid in the clutch master cylinder reservoir on the firewall is low. Make sure you take the "cup" out of the reservoir after you remove the cap and look under that.
Old Feb 5, 2004 | 11:53 PM
lynkje08's Avatar
lynkje08
Thanks for all the help
The fluid was low and I am in business.
What a wonderful website!
Old Feb 5, 2004 | 11:59 PM
BrianA's Avatar
BrianA
Nice to have you here at FTE and glad you got the problem resolved. It IS a great website!
Dave and Jimmy to the rescue!!
Old Feb 6, 2004 | 12:04 AM
Racerguy's Avatar
Racerguy
Good to hear that it works again
You might have to look at figuring out where the fluid went to though.
master link
Oct 11, 2012 01:21 PM
marks500
43
Jan 23, 2011 09:13 PM
Boss300
Oct 31, 2009 01:31 PM
vantonio
1978 - 1996 Big Bronco
Nov 27, 2004 12:39 AM
lkt
1983 - 2012 Ranger & B-Series
Jan 14, 2003 12:50 PM
