Sponsored by: Real Truck
2003 5-Speed auto
Old Jan 18, 2002 | 07:59 AM
Monsta's Avatar
Monsta
Sit. Stay.
2003 5-Speed auto
Old Mar 22, 2002 | 09:54 AM
Fords For Ever's Avatar
Fords For Ever
2003 5-Speed auto
I have seen a couple of posts talking about a 5-Speed auto as a possiblity for the 2003 SD V10. Does anyone know for sure? I can't find a used CC the way I want it and the users of FTE have educated me (thanks!) that the 2002 has a Dana 60 instead of Dana 50 front axle. I have witnessed a Diesel break it's front end while in the snow with chains pulling a horse trailer (never found out specifically what broke). So... Is it worth waiting for the 2003? The tranny appears to be the only major upgrade, the price will no doubt be higher and its at least 1/2 a year away. If anyone finds a reliable source about 2003SD upgrades, please share.
Old Mar 23, 2002 | 09:15 AM
NoMo's Avatar
NoMo
2003 5-Speed auto
Don't know how accurate it is since all the economic troubles have hit, but you might read [link:www.bonforums.com/powertrain/trans_new5r110.htm|this].
Old Mar 25, 2002 | 08:03 PM
4x4x4x4's Avatar
4x4x4x4
2003 5-Speed auto
I talked to my brother today and he works at the transmission plant where the SD automatics are produced.He stated that to the best of his knowledge the 5spd.auto will be phased into production sometime around August.Sounds like a 2003 addition.I don't know if all Super Duty versions will have it available at once or not.
Old Apr 3, 2002 | 02:24 PM
PierceLantz's Avatar
PierceLantz
2003 5-Speed auto
The new 5-speed auto is the replacement of the 4R100. It's called the 5R110W (W is for the wide 1st ratio for towing) They start production behind the diesel in August, then behind the gas after the first of the year. The ratings are 550 lb-ft Gross, 520 lb-ft Net for general applications and up to 600 lb-ft for motorhomes. The misleading factor of these numbers is the fact that they need torque management during the shifts to live through the torque of the engine. So really, they juice the numbers up to compete with the Allison 1000 Series, but can't live in their high torque environment. Basically Ford is inflating the numbers and dumbing down the engine's power. Also, as far as improvements to the 4R100, Ford basically put a fifth range on the back and kept alot of teh internals the same. The shaft diameters and clutch packs are no better than before, thus presenting the same problems with longevity as before. I don't mean to throw a bomb, but as near as I can see, there isn't a Ford auto worth waiting for.
Pierce
Old Apr 25, 2002 | 05:01 PM
MichaelG's Avatar
MichaelG
2003 5-Speed auto
I hear the 5 speed (and 6.0L) is official, dealers can enter orders for build starting 11/4, at least on the F250, F350 and Excursion.
Does anyone have any more specs/info on the 5 speed? The BON stuff is VERY old.
I also wonder when it will get into the E-450/E550 chassis and the F53 motorhome chassis?
