1978 - 1996 Big Bronco
not fast enough
Old Feb 3, 2004 | 03:23 PM
LADGE99's Avatar
LADGE99
not fast enough
i have a 96 eb w/ a 351w;k&n fipk,edelbrock performer hds and cam,jba headers(nickle),3 in dual thru flowmasters & hi flow cats.,jet chip 31x10 tires and stock gears(not sure of ratio)whats the best way to build more torque/hp from here?.
Old Feb 3, 2004 | 03:34 PM
jeep8589's Avatar
jeep8589
without a doubt a supercharger. A roots blower is the best for a low end torque application.
Old Feb 3, 2004 | 06:59 PM
crazed87bronco's Avatar
crazed87bronco
hey ladge99 how much power increase did you see with the edelbrock performer heads
Old Feb 3, 2004 | 10:34 PM
WhëëlMå1's Avatar
WhëëlMå1
You say its not fast enough. Please clarify.... off the line? Top end? The stock gears should be 3.55s. Once we know what kind of info you want, we can help you.
Rich
Old Feb 4, 2004 | 01:22 PM
LADGE99's Avatar
LADGE99
WITH THE HEADS AND CAM I NOTICED A REAL SIGNIFICANT CHANGE.LOW END SOMEWHAT SO AND TOP END DEFINATELT.I WANT 2 DEVELOP MORE LOW END PWR.THE GEARS ARE 3:55(H9, ON DOOR PANEL:LIMITED SLIP)THANKS AHEAD FOR ANY HELP.
Old Feb 4, 2004 | 01:51 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Someyone needs to lay off the shift key.
Sorry, I could'nt resist.
Old Feb 4, 2004 | 02:02 PM
WhëëlMå1's Avatar
WhëëlMå1
Well the easiet way to feel more low end power is to swap youre gearing to something stouter (in this case 4.10s). Although you wont gain any power, the mechanical advantage provided by lower gears will make that truck jump off the line, or ease into traffic with a trailer in tow, etc.. Is the EB a bronco, or a truck? I also see that you have a JET chip. Has that done anything for you? I have heard nothing but bad news about them (ie dont make power, and can actually make you make LESS power). Is mileage a concern? Is this a daily driver?
Rich
Old Feb 4, 2004 | 03:00 PM
crazed87bronco
another way to get low end power is to get a bbk throttle body and a edelbrock 5.8L truck intake as others said i would get a gear change then go from there
Old Feb 4, 2004 | 03:31 PM
LADGE99's Avatar
LADGE99
THE JET CHIIP DID((DOES STILL)INPROVE PERFORMANCE.THE TRUCK IS AN EB BRONCO AND THE CHIIP REALLY HELPS THE A40D TRANS SHIFT BETTER(USED 2 WIND OUT A LITTLI) AND SMOOTHER.I WITH ALL OTHER EQPT REFERRED TO INSTALLED I HAVE DRIVEN IT WITH AND WITHOUT THE CHIP ANDSTILL NOTICE A DECENT HP IMPROVEMENT WITH THE CHIP.IT IS A DAILY DRIVER( IN MASSACHUSETTS)AND SORRY ABOUT THE ALL CAPS LETTERS,KEY IS STUCK.ALSO,THANKS FOR THE TIPS,I'M THINKING OF TRICKFLOW INTAKES(UPPER/LOWER)
Old Feb 4, 2004 | 06:32 PM
Himura77's Avatar
Himura77
LADGE99
I'm on the same page as you. I believe i had a superchip installed, instead of the Jetship, but other than that we're on the same page. I'm happy though. Not too big Hp change last time I dyno (24Hp increase at rear wheel, 32Hp at the engine). But that was before the Intake Manifold and tranny/oil cooler additions. I'm thinking of swaping the fan to an electric one. The good thing about it all is that most of the little changes I can put them on a brand new 302 offered by Ford (rated at 340Hp).
Old Feb 10, 2004 | 11:43 PM
COBRAjrb's Avatar
COBRAjrb
correct me if im wrong but this is just me that heavy of a truck your going to need about 500-600 to make it fast about 7 to 800hp to get u up in the 12's u no weight to horse power ratio. if u got an efi engine your going to need mass air kit. or all those mods wont work well.
Old Feb 10, 2004 | 11:49 PM
DW2455's Avatar
DW2455
is your injection system speed density or mas air? or you still running stock injectors? DW
Old Feb 11, 2004 | 12:49 PM
LADGE99's Avatar
LADGE99
STILL RUNNIN STOCK INJECTORS. I FIGURE ON CHANGING THEM WHIN I REPLACE INTAKE MANIFOLD/PLENUM.ITS A 96 EB BRONCO 351W MASS AIR.MODS ARE LISTED ABOVE.I GUESS WHAT I WANT 4 A START IS MORE LOW END TORQUE. TO BE ABLE TO SMOKE THE REAR TIRES OFF THE LINE.
Old Feb 11, 2004 | 01:39 PM
bigwhtbco's Avatar
bigwhtbco
go w/ some 4:10's. that will definently help you smoke up your tires nooooo problem. assuming you have stock rear tires
Old Feb 11, 2004 | 01:43 PM
WhëëlMå1's Avatar
WhëëlMå1
Please refrain from using the caps lock for youre posts. Was this bronco purchased to compete with mustangs? Its just not going to happen. Do you have a budget in mind? To smoke the tires off, 4.10s and a supercharger = smoke!. If you give us some numbers we can work off, you might get some more direct information.
Rich
