Hello Ford Fans, I am new here ( been a week actually ) I finally came back to Ford after a 3 year stint with a 98 Dodge Ram 4x4 5.2L QuadCab shortbed, Ballsy but WAY EXPENSIVE TO FIX. had a 94 F-150 4.9 inline 6 Cyl. 4X2 Luved it, would go anywhere, Never had an issue with it, ( except the altntr needing replaced once ) Prior to the Dodge, Never will stray away again. Besides that, Does anyone have any ideas on how to modify the light switch on my 03Ford-F150-4X4-5.4L-Regcab-Flrside, So that I can turn on my Fogs by themselves, or with the running lights ( The I am cool Look at dusk look) or in Bad weather for visibility. I hope that this turns out to be the best site that I have joined...
I've been an electronics tech in the NAVY for twenty years. The best way is to run seperate fuzes and relays off the battery using a link to the ignition or starter switch to kick the whole works on....
If you need it or want it I can probably dream up some way to do it....
Me and at least ten other vets here that like to play with stuff.....
