Under load turns cause roughness
Old Feb 3, 2004 | 01:51 PM
cwminard's Avatar
cwminard
Unhappy Under load turns cause roughness
I have a 2000 F-250 Super Duty 7.3 Diesel short bed. I pull a 5th wheel and when making a R or L turn, the truck makes a rough sounding noise that seems to work off the wheels, because it comes and goes as the wheels rotate.
I first thought it was my 5th wheel causing it when pulling under load but I also noticed it without pulling anything, when I was going up a slight incline and making either a R or L turn.
Anyone heard of such a thing or know what might be happening?
Thanks
Old Feb 3, 2004 | 02:07 PM
shendoa's Avatar
shendoa
might be rear wheel bearings or brake mecknazin rubbing on drum.
Old Feb 3, 2004 | 08:54 PM
mybigredford's Avatar
mybigredford
i have a similar problem, it seems alot of the time when i crank the front wheels hard to the right i get a knocking noise coming from the front end, when i turn hard left there is nothing, i am also under no load, and the noise happens when i am at a very low speed, anyone with any ideas, i was thinking a bad u-joint.
later
Old Feb 4, 2004 | 10:00 AM
cwminard's Avatar
cwminard
Thanks to all for your comments.
Old Feb 4, 2004 | 11:52 AM
shendoa's Avatar
shendoa
4x4 sometimes make a clunk when turning, u joints binding= but the u joints are probably ok = cure don't turn the stearing wheel all the way or put a stop so it won't turn so much.
wildbyon
May 22, 2014 09:58 AM
JR58
All Things Towing
15
Nov 26, 2013 11:02 AM
Sunnybrook
24
Jun 29, 2007 09:39 PM
joemar81
May 31, 2005 04:12 AM
andym
1978 - 1996 Big Bronco
Aug 31, 2003 11:05 PM
