new 302 EFI, need help on computer chip
Old Feb 2, 2004 | 10:32 PM
riverguides's Avatar
riverguides
Hello everybody, 85 F-150 EFI Auto. 4x2 (re-built trany. and rear end) - 260,000 mi. on body, 10,000 on new engine. I'm in Denver, Co. and travel quite a bit in the high country. Lots of high mtn. passes ( 8500 feet plus ). No mods. on motor except K&N filter. I know at some point I'll get cat back duals, (and thats about it) but could you suggest a computer chip for this? Is there a chip company or something I could contact? I just need more hp for the mtn. passes, no towing, just hp. No racing around town, just need more power for mtn. highway climbing. (descending is fast and furiuos with little accelerator work!) Also, I can't get my passing gear after 10,000 feet (altitude).
Any thoughts?
Thank you kindly
Old Feb 3, 2004 | 08:21 AM
nickmobile67's Avatar
nickmobile67
I don't know if you can chip a truck that old. I think there is a seperate forum for chips and computer mods, and I think the moderator also makes chips. Get in contact over there, they can tell you.
How many miles on the motor? I don't usually like to do performance upgrades on an old engine unless it's been rebuilt. And that sounds like hard work for an old engine.
Old Feb 3, 2004 | 09:33 AM
GregoryB's Avatar
GregoryB
I agree with Nick... basically with the KandN you have done the logical thing... the fact is you have a little engine and are up so high you just don't have enough oxygen available for more power.
Cubic inches is what you need.... more fuel into the air you have available will only decrease gas mileage.... this is more a need for change in your expectations from your truck... it is doing the best it can .....
Old Mar 21, 2004 | 10:45 PM
TwoXtreme99's Avatar
TwoXtreme99
yeah you probably may be hurting from lack of oxygen. computer compensates a little, but probably not enough for that. Ford actually equipped some factory vehicles for high altitude applications. you may want to check somewhere on that to see what they did. probably the easiest and cheapest fix for this would be a high performance cam to get the power band a little closer to wear it would benefit your usage.
Murphy IRE
Sep 24, 2016 10:48 AM
EffieFord
141
May 26, 2013 08:32 PM
tor98008
Dec 31, 2005 03:53 PM
riverguides
Oct 22, 2002 10:12 PM
