heater gone bad
Old Feb 2, 2004 | 08:19 PM
pdgkdg
Guest
Posts: n/a
heater gone bad
I recently bought a nice one owner 78 f150 2 wheel drive with a 300 automatic. My problem is the heater works fine when the vehicle isn't in motion, but as soon as I take off the temperature guage drops and so does the temperature in the cab. I have replaced the thermostat with a 160 degree unit and replaced the water pump. Still nothing. I also noticed the fan shroud is missing, but I figured it would help me if I had an overheating problem. Any help?
Old Feb 2, 2004 | 09:26 PM
Mark VIII's Avatar
Mark VIII
Are the both heater hoses getting hot? It could be a plugged heater core. Also sounds like the thermostat is on the low side, you might want to try a 180* or 190*
Old Feb 3, 2004 | 01:55 AM
Wyoming10's Avatar
Wyoming10
190 for winter... A 160 won't cut it in the cold.
Old Feb 3, 2004 | 02:28 AM
Torque1st's Avatar
Torque1st
Posting Legend
Welcome to FTE!
190 for all year round. For low ambient temps use a "Ford Thermostat" with a 300-6. Put a piece of cardboard in front of the radiator that cuts off about 1/2 of the area.The cold air rushing over the sides of that engine will pull more heat out than you can generate. Or you can buy a canvas "winterfront" like the big rigs use.
Put the fan shroud on. The engine will overheat without it when it gets a little warmer.
Make sure all of your baffles are in place also. Believe it or not they help keep the engine warmer in winter and cooler in summer.
