Do i have all the wires?
You guys rock!!!!
Scott
First thing there are two starter solenoids on the 86.
One is right behind the passenger side battery and looks just like a gasser solenoid, this is where the wire from the key switch should go to. The battery, alternator, glow plugs and fuse panel are all tied in on the first 3/8 lug battery side.
The small #10 stud on the side goes to the start position on the key switch.
The other 3/8 lug has a 10 guage wire going down to the solenoid on the starter.
The second solenoid has a 3/8 lug for the main battery cable and a smaller screw for the 10 guage wire from the first solenoid. Depending on the starter on your truck you may have another 3/8 lug for the strap or wire going into the starter.
I would recomend the Mitsubishi gear reduction starter over the Delco starter for your truck. They spin the motor much better.
There is a relay on the fender that the Glow plugs go to from there there is a 4 Ga. jumper wire to the Battery side of the starter relay (also on the fender) from there there is a 10 Ga.. wire that goes to the starter solenoid on the starter. The alternator and fuse panel are connected to the battery side of the glow plug relay. There is also a hot wire there that I have no clue where it goes. I originally found it on the starter side of the Starter relay. (The relay was fried) I currently have it hooked to the battery side of the glow plug relay. Will this work without causing problems. or should I move them to the starter relay? and should there be a fuse link in the starter solenoid wire?
Thanks again
Scott
