The differentials use a multi-grade gear oil like 85w90 or 75w140 if you want to go synthetic. The transfer case will take Dexron/Mercon transmission fluid. Any good brand name that is readily available is fine. Even the house brand lubricants from the chain auto parts stores are good. Many are manufactured by the major oil companies and packaged under the chain stores' name.
Thanks for the info, Im kinda new to broncos, this is going to be a very stupid question, but is the transfer case underneath where the front drive shaft goes into? That box looking thing?
It matters. Some, probably yours, take gear oil and some like the BW1345 and BW1356 take tranny fluid. Something else to keep in mind is someone could have changed tcases.
The owner's manual recommends transmission fluid, rather than gear oil for the transfer case regardless of which one you have. I run 80w/90 in my front diff, 75w/140 in my rear diff and synthetic ATF in my np205. I have a '78 Bronco.
