48f1
Old Feb 2, 2004 | 07:26 PM
tlb's Avatar
tlb
48f1
Just purchased a 48 F1 with 302 V8 and C4 automatic. Truck is solid but needs repainted and rewired. The truck has been converted to 12 V but i want to use the original gages. Can i convert the 6V gages to 12V? Also can the heater be wired to 12V wthout burning up motor?
This is my first resto project so i will need help.
Old Feb 2, 2004 | 08:26 PM
mtflat's Avatar
mtflat
You need a voltage drop regulator for the gauges. They were used in Ford vehicles thru the 70's. Mount it on the power wire between the circuit breaker and the first gauge.
You also need a larger regulator for the 6 volt heater - you will burn it up on 12V. I got my volt drop from Hotrod and Custom Supply, FL but you could likely pick one up at your local parts house.
Old Feb 3, 2004 | 04:57 PM
tlb's Avatar
tlb
Thanks for the info. Now that i know what i need i should be able to find the parts.
Old Feb 3, 2004 | 05:00 PM
mr4speedford's Avatar
mr4speedford
may I ask what part of northeastern ohio are you from? Akron here. Welcome to the site! -4speed
Old Feb 3, 2004 | 05:07 PM
tlb's Avatar
tlb
I am from East Palestine just south of youngstown. I just purchased this truck and am very excited for spring so i can get it on the road. This truck won't be a trailer queen. its going to driven everyday and if i need to haul something i will. No point in having one and just letting it sit.
Old Feb 3, 2004 | 05:42 PM
mr4speedford
Cool, maybe I'll see you around at a show or cruise inn? Get some pics of the ole' beast up if you can, I'd love to see it. -4speed
Old Feb 3, 2004 | 06:01 PM
tlb's Avatar
tlb
I will be around at swap meets at canfield and as many car shows as i can. I will get some pictures up as soon as i can.
Old Feb 3, 2004 | 11:56 PM
mtflat's Avatar
mtflat
When I saw tlb from ne ohio I did a double take. My intials are tlb and i was born and raised near columbiana, went to school at beaver local. Small world huh?!
Welcome to FTE - it's a great place to hang out.
Old Feb 4, 2004 | 12:22 AM
F-ONE's Avatar
F-ONE
my truck
That sounds like my truck except I'm running the old floorshift 3spd behind my 302. I'm going to replace the motor in my heater "an ancient universal" with a new motor. I have heard s-10 ect. heater motors may work. I'm going to pull the motor and take it too the parts store to find a close match.
Old Feb 4, 2004 | 04:58 AM
tlb's Avatar
tlb
I am from east palestine. went to ephs.
Old Feb 4, 2004 | 05:45 PM
zonkola's Avatar
zonkola
Re: my truck
How is the old three speed working out now that it's hooked up to the 302? Who makes a transmission adapter for this?
Old Feb 5, 2004 | 02:40 AM
F-ONE's Avatar
F-ONE
302 bellhousing
Its not really an adapter. Its a cast alluminum bellhousing. When I had it out, swapping the wore out 79 302 for a newly overhauled 68, I did not notice any brand name. It seems that I remember seeing this same type of bellhousing in a street rodding magazine. Offenhauser may have made it. It adapts smallbock fords to round bolt pattern flathead transmissions from the 30s to early 50s F-1s. The 3 speed does very well considering it really needs a rebuild. It has wore out at least one flathead and is on it's second 302. It shifts well and other than being a little clinky and clanky it does fine. New bearings should take care of that. Honestly I was going to just run that old 54 year old transmission temporary and replace it but after driving with it for the past 2 years I really enjoy it and think it is more than adaquate behind that 302 even though it is 54 years old. The past month I've had to drive my 50 back and forth to work about 25 miles one way and I have had no problems.
Old Feb 5, 2004 | 11:38 AM
zonkola's Avatar
zonkola
Re: 302 bellhousing
Thanks for the info! This sounds interesting....
Old Feb 5, 2004 | 04:54 PM
tlb's Avatar
tlb
i originally wanted a flathead 3 speed but the truck i bought was to nice to pass up. I may someday want to replace the 302 with a flathead. nothing sounds better than a flathead with dual exhaust and glass packs.
can't wait for spring.
