new timing chain question (351M)
Old Feb 2, 2004 | 11:07 AM
Galaxie427's Avatar
Galaxie427
Hi all,
Well, I got my new timing chain from Summit. The listing was for 351C, 351M, and 400. Now, when I removed my old timing chain set, I rotated the crank to make the dot on the crank gear line up with the mark on the cam gear (didn't care where TDC on #1 was, or anything else). The old set had the crank dot in line with the keyway. The new set has the dot about 30° off the keyway. Speaking of keyways, the new set has roughly a .25" key slot, halfway (axially) through the gear, the old set has a .1875" slot the full length of the gear. The new cam gear pointer is 180° away from the old cam gear. I'm guessing I need to return this timing set ASAP. I've heard about the factory retard (not a reference to a Ford worker) built into the stock timing set, and I'd like to not have that when I put this all back together. What's my next step?
Thanks in advance (so to speak)!
Old Feb 2, 2004 | 12:14 PM
F150daniel's Avatar
F150daniel
stock set is retarded about 4 (where is that deg. simble on the key board)
Old Feb 3, 2004 | 03:39 AM
willd's Avatar
willd
Look at the directions, or call summit. I cant remember, but one is 4 deg adv one is straight up and one is 4 deg retard.
They can help you out there.
