oxygen sensor question
Old Feb 2, 2004 | 11:03 AM
sail2244's Avatar
sail2244
Question oxygen sensor question
I have a 1984 F150 I6 auto Tfi ignition Tiff IV.
It Has all of the sensors hooked upband everything seems to be working except the egr system (both the solenoid and the valve are bad, line from the exhaust cracked ) which needs complete replacement.
I have a pretty good idea about the function af all of the sensors except for the oxygen sensor.
Since it is a carb system, what does the oxygen sensor control?
The dithering valve on the carb? the egr?
Any ideas?
Old Feb 5, 2004 | 07:32 AM
low-side's Avatar
low-side
Not too familiar with Ford feedback carbs, but there should be some sort of mixture control valve by '84.
Old Feb 5, 2004 | 12:19 PM
gatesj's Avatar
gatesj
O2 sensor is always used to read mixture, and usually to adjust it.
Old Feb 5, 2004 | 02:02 PM
wtroger's Avatar
wtroger
The o2 sensor's input is used along with other sensors to control spark advance and the air bypass solenoid on the feedback Carter carburator. I changed mine one time and it was like I had put a new motor in it. It ran that much better.
Old Feb 5, 2004 | 06:30 PM
sail2244's Avatar
sail2244
Thanks for the information
Old Feb 5, 2004 | 06:40 PM
hoxiii's Avatar
hoxiii
Something else to consider i that the computer can only adjust properly if the baseline setting is set properly. On the base of the carb where the idle mixture screw is on a normal carb is an air bypass screw. this is what is used to adjust the feedback carb. Just remember taht it's the oppsite of an idle mixture screw. in richens the mix and out leans it.
Justin
wakum6
Nov 30, 2014 06:02 PM
1999fordpiece
1997 - 2003 F150
Oct 1, 2013 06:08 PM
Montana250
Jun 3, 2013 06:40 AM
gener46
1978 - 1996 Big Bronco
Apr 23, 2006 10:37 PM
kjfassoc
Jan 11, 2005 11:37 AM
