Originally posted by Andysutt I get how you make the board
but not sure how a C-2 P-9 has anything to do with the score
if it was 22 29 i could understand.... 2 on the 2s, and a 2 and a 9
c-2 would be that carolina would have to end the game with a score of 2, 12, 22, 32.... so long as the last number in the score was 2. Pats would have to have the last number in their score to be 9: 9,19,29..... In order to win you have to have carolina matching the 2 and the pats matching the 9 if those are your numbers.
It's a grind and each team gets 10 numbers across the grid thuse allowing for 100 squares.After the squares are full of names of people who purchased a square,
The numbers 0-9 are picked randomly and placed in one direction for one team & then the same for the second team ,
the numbers are adjacent to each row.
Thus you can have the same combination to MATCH the LAST Number in the score for both teams but by different people unless due to luck of the draw.
ie:
________Patriots______
*| 8 4 3 5 9 0 1 6 2 7
*|1
P |7
A |2
N |4
T |9
H |8
E |3
R |5
S |7___________________
To determine the numbers for each person you find the numbers that correspond with your name intersected the numbers.
