Sponsored by: Auxito
changing bulbs
Old Feb 1, 2004 | 05:04 PM
mnk1220's Avatar
mnk1220
changing bulbs
i cant seem to get my hand in there to change the driver side headlight bulb! so i need to take the entire light out?
thanks
Old Feb 1, 2004 | 05:15 PM
TLD's Avatar
TLD
It would help to know what kind of vehicle ????????
Old Feb 1, 2004 | 05:17 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
That's a big one
Old Feb 1, 2004 | 05:19 PM
mnk1220's Avatar
mnk1220
sorry!
2003 f150 super crew
Old Feb 1, 2004 | 05:26 PM
TLD's Avatar
TLD
I think if you look there may be two black pull pins that you remove. Check owners manual and it will tell you exactly how this is done.
Old Feb 1, 2004 | 05:28 PM
mnk1220's Avatar
mnk1220
thanks yea we are still waiting for the owners manual but thank you
Old Feb 1, 2004 | 05:32 PM
Beast12's Avatar
Beast12
Do a search for this in the 1997-2003 F Series trucks forum. I did one and found this https://www.ford-trucks.com/forums/s...5252Bheadlight But if that doesn't help go look in that forum! Good luck!
-Matt
Old Feb 1, 2004 | 06:25 PM
mnk1220's Avatar
mnk1220
thanks
Old Feb 1, 2004 | 06:38 PM
Beast12's Avatar
Beast12
Did you end up getting it fixed? If so, did you find the answer here or in your manual. Just curious.
-Matt
Old Feb 1, 2004 | 11:21 PM
mnk1220's Avatar
mnk1220
tomorrow we are going to try and do it again it was way too cold to go back out there!
Old Feb 2, 2004 | 06:28 AM
Beast12's Avatar
Beast12
Well, good luck. If you have any other questions be sure to stick around. Welcome to FTE! It's a great place with a WEALTH of useful information.
-Matt
Old Feb 2, 2004 | 04:54 PM
mnk1220's Avatar
mnk1220
here we go again we pulled the tabs up and light is kinda loose does it just pop out?
Old Feb 2, 2004 | 05:01 PM
Beast12's Avatar
Beast12
I haven't done it but from the sounds of the link I gave you it should just slide out. Try wiggling it around a bit.
-Matt
Old Feb 2, 2004 | 05:04 PM
mnk1220's Avatar
mnk1220
yea its not comming out who knows!
Old Feb 2, 2004 | 05:15 PM
AzPete's Avatar
AzPete
The way you are going about it is correct. Pull up on the two tabs and wiggle the light forward. It is a tight fit and in your part of the world, it may have a bit of an ice build up. The pins on the back of the light fit into a slotted hole. You move the slot when you pull up on the tabs. Keep tinkering and it will fall out for you.
