Sponsored by: Auxito
changing bulbs
Old Feb 2, 2004 | 05:45 PM
mnk1220's Avatar
mnk1220
got it out now cant get6 it back in ugghhhhhhhhh
Old Feb 2, 2004 | 06:16 PM
mnk1220's Avatar
mnk1220
got it back in now the high bean is out on the passenger side? hit the light it went back on loose conections?
Old Feb 2, 2004 | 07:01 PM
AzPete's Avatar
AzPete
Sounds like either loose connection or a bulb with a broken filament that just happened to connect when you hit it. I would replace it if the connection looks tight. Usually you can hit the light again and it will go out for good.
Old Feb 2, 2004 | 07:45 PM
mnk1220's Avatar
mnk1220
yea we did drop the bulb
Old Feb 2, 2004 | 07:56 PM
AzPete's Avatar
AzPete
And I know you said "oh darn" didn't you. Keep you fingers off them also as body oils will cause hot spots and they will blow sooner.
Old Feb 2, 2004 | 11:30 PM
mnk1220's Avatar
mnk1220
yea i learned that the hard way! what size bulb are the fog lights?
Old Feb 3, 2004 | 08:34 AM
AzPete's Avatar
AzPete
Not sure on the fog lights as I have not looked at them since I went to 55 watt bulbs and wired them on all the time about 1.5 years ago. Any auto store should be able to tell you.
