Cooked Spark Plugs
Old Feb 1, 2004 | 10:13 AM
mr_toad's Avatar
mr_toad
Cooked Spark Plugs
I have a 98 XLT Explorer, I went to change the spark plugs and they were seemingly welded into the heads. I managed to get a couple out using a cheater bar. The rear drivers side plug snapped off at the head. I tried using an easy-out to pull it, and snapped that in half as well. The Ford Store mechanic told me he has heard a number of complaints about this sort of thing, that and the attempts to try and change the rear passenger side spark plug. I was told that if I didnt use Ford spark plugs that they would run to hot and weld themselves to the head. Anyone else have this sort of issue and/or idea on removing a stuck plug threads? Mechanic told me I'd have to take the heads off to remove the threads, just not sounding like alot of fun.
Old Feb 3, 2004 | 07:31 PM
rowiebowie1's Avatar
rowiebowie1
Sounds like no grease was used and the plugs were over-torqued.
I've heard aluminum heads require (might I say demand) an anti-sieze grease be applied to sparkplug threads to prevent this very thing.
Alas, I have no recommendations on removal and proper torqe of new plugs, but I'm sure someone out there has. Good luck! Roy
Old Feb 3, 2004 | 09:41 PM
ltfox's Avatar
ltfox
OUCH......... that dosent sound good. Good luck and let us know how it goes.
Old Feb 4, 2004 | 05:10 AM
marragtop's Avatar
marragtop
The best way to get to the rear passenger plug is thru the wheel well. If you can get a straight shot at it, try using another easy out. Last ditch effort is to drill it and install a heli-coil kit. As one of the previous posters said, always use anti-seize when installing plugs. I know that doesn't help you at all now. Good luck.
Mike
Old Feb 4, 2004 | 10:40 PM
mcCrank's Avatar
mcCrank
That sucks pretty hardcore, like above you could always drill it, but I dont think that would be a deterrent from having to take off the heads.
Old Feb 5, 2004 | 09:26 AM
thelonerangerxlt's Avatar
thelonerangerxlt
If you can get the broken eazy-out removed, then try again with another one, but heat the area around the plug first. Use a propane torch, and be very careful about fluid lines, wiring harnesses etc., and especially fuel lines. SAFETY FIRST!
Old Feb 7, 2004 | 12:48 AM
mcCrank's Avatar
mcCrank
If it makes you feel any better I snapped off one of the screw heads to my catalytic converter today. I almost cried.
Jose A.
Aerostar
27
Oct 28, 2012 03:31 AM
Plain Jane
Oct 8, 2011 04:50 PM
klr650goldwing
Modular V10 (6.8l)
Mar 15, 2011 11:24 PM
roc.r1
Jun 28, 2004 02:11 PM
GoldStarKimber
Modular V10 (6.8l)
17
Mar 1, 2004 12:58 PM
