Fuel presure
Old Feb 1, 2004 | 09:16 AM
Wellcraft's Avatar
Wellcraft
Fuel presure
hvat is the fuel presure ona 1992 7,3IDI. Lift pump presure
Old Feb 2, 2004 | 06:03 PM
MRZ's Avatar
MRZ
I believe 8 to 10 psi? That is from my foggy memory, so I may be wrong....
Old Feb 3, 2004 | 12:22 PM
bilder12's Avatar
bilder12
I believe 7 psi will make it run properly. Are you not using the engine in a boat? If so, that may be cause for a higher pressure and you could obtain that by using an adjustable electric pump. This would work better if it had to "push" the fuel rather than "pull" it.
