Originally posted by construction site dk5122 thank you for your info. Would you also know where to get a wiring digram for a 1992 F-250 instrument culster?
if you don't mind me asking, what do you need the wiring diagram for?
absolutely go skyjacker on that make/model truck! everything aligns up perfectly...might have to drill the holes a lil but i doubt it! and i highly suggest National Tire and Wheel. They do you right. I have never had problems with NTW but 4Wheel Parts will give you the run around!
jason how dose your truck sit? I lifted my 92 F250 and it sits level
but it looks like the rear end is lower.I was wondering if yours
had the same problem
Jason my truck is lifted about 2" that is the way I bought it. The list was not done very good. The guy just put blocks upfornt an in the rear. The truck sits very level. I am wanting a 4"-6" lift. I will also be using air bags for load leveling and load handling.
Sorry construction site no bad intentions were implied.
I had a TrailMaster kit installed (4" the time guide says it is aprox 8 hours.)
My buddy and I installed a Rancho kit on his 92 F250 Took a weekend and was fairly straight forward to install.
If you have a friend to help, some air tools , jacks and a weekend you should be able to do a lift kit install yourself.
My "pal" wasnt around (go figure) when I wanted mine done
so I paid about 500.00 to have it installed and aligned.
Thanks for the info sleepysal. I have a full shop and air tools. But I have never done any thing like this before. I thank you for your input and ideas. I will let you know how it goes and what kind of kit I install
constructionsite
-Alan_
