Thermostat
Old Feb 1, 2004 | 07:49 AM
dj8667's Avatar
dj8667
Question Thermostat
I have a 1986 F-150 300. I have bored it .030 and the head was shaved .008. It also has a Crane Truck power cam and a Melling high volume oil pump. Does any one know weather I should go with the stock, 180, or 160 thermostat.
Thanks,
D.J.
Old Feb 1, 2004 | 10:36 AM
NM5K's Avatar
NM5K
STOCK!!!! 195 degrees is usually stock, but double check for your app. Don't use cooler stats. It causes more wear, more crud eventually, and the engine is less efficient at the cooler temps. MK
Old Feb 1, 2004 | 01:19 PM
MavStallion's Avatar
MavStallion
EFI engines are designed to run at certain temps. Don't put a cooler stat in. If cooling is a problem, go with an extra or better replacement fan.
Old Feb 1, 2004 | 05:04 PM
dj8667's Avatar
dj8667
Its not EFI its carbed. On my freshly rebuilt engin you guys still reccomend stock 195 thermostat?
Old Feb 1, 2004 | 07:30 PM
rmt's Avatar
rmt
Yes.
Icicle
61
Oct 29, 2014 05:13 PM
Pishnook
Nov 18, 2011 07:47 AM
dj53
Mar 20, 2007 05:05 PM
youdog99
Aug 24, 2002 07:56 AM
