1966 - 1977 Early Broncos
Power Steering Conversion in '69
Old Jan 31, 2004 | 05:55 PM
BroncoRedneck's Avatar
BroncoRedneck
Question Power Steering Conversion in '69
Hi, I wanting to convert my '69 to power steering. I have a friend who is giving me a D44 front end out of a '76 F-150. It has everything with it including the steering gear box, pump, tie rod, main drag link, and hoses. I was wanting to know what I will have to do to get this steering to convert onto my Bronco. Will I have to fabricate any brackets and can I modify my current steering shaft to use with power steering. All suggestions will be appreciated. Thanks
Old Feb 2, 2004 | 09:11 PM
70bluebronco's Avatar
70bluebronco
I was looking at the F-150 steering box conversion when I found a stock gearbox.Read the tech article at bcbroncos.com that tells how to convert your box for the proper internal swap with a 81 or 82 2 wheel drive box.I think he invented that conversion.Also I hope you got the steering knuckles and brake parts.Excellent way to put front disc brakes using all Ford parts.Good luck!!
