Sponsored by: Innova
Speed Sensitive Volume Adjustment???
Old Jan 31, 2004 | 02:32 PM
NDrum2005's Avatar
NDrum2005
I have an 03 F-150 with the single CD stereo in it. I have heard that there is speed sensitive volume adjustment on the 6 disc stereo, does antone know if this feature is available on the single CD stero?
Thanks
Old Feb 1, 2004 | 10:35 PM
02TruBluF150's Avatar
02TruBluF150
Talking
Easiest way to check, is to hold the volume/On-Off button in for 3 to 7 seconds. If you have SSV it will then let you adjust it by turning the volume ****. Ranges from 0 to 7. Stereo has to be on while you are testing/setting.
Greg
Old Feb 4, 2004 | 02:12 PM
PrPlayboy's Avatar
PrPlayboy
SSV to me always seems to just be a boast like the loud button. I turn mine off.
Old Feb 4, 2004 | 02:17 PM
Peties3's Avatar
Peties3
I have the singel cd unit as well with the SSV feature. It is the head unit that has RDS. Whatever that means. Just hold the button in like mentioned before.
Mark
Old Feb 4, 2004 | 04:57 PM
MrBSS's Avatar
MrBSS
Yeah, the speed sensitive volume gets wierd unless you just use a little. I put mine on 2, and it just compensates for road noise. Actually I may set it a notch higher with the snow tires.
The RDS is Radio Data System, which allows the radio to post a line (or several scrolling) such as their call letters, location, or music type. Like the SSV, it does not come activated, but must be turned on (see owner's manual).
wkbrdtx
Aug 6, 2013 05:35 PM
Blue Jeff
Jul 13, 2004 08:12 PM
dusty1
2004 - 2008 F150
Mar 19, 2004 12:43 PM
swalke2
1997 - 2003 F150
Jul 30, 2003 10:05 AM
