Sponsored by: Real Truck
Keyless entry on used SD?
Old Jan 31, 2004 | 02:17 PM
keence's Avatar
keence
Question Keyless entry on used SD?
I purchased an 2000 XLT PSD 4X4 - It didn't come with a remote, but was wondering how to tell if it came from the factory with one. Does not have a keypad on the door.
If it doesn't have one can I add one fairly easy?
Thanks!!
Keence
Old Apr 12, 2004 | 08:14 AM
Pig Pen Jr's Avatar
Pig Pen Jr
I know this is kind of old, but did you ever add the keypad? I just got a '97 250 HD and was wondering if I would be able to install one on it.
Old Apr 12, 2004 | 10:43 AM
rmartin11's Avatar
rmartin11
i brought ny 2002 f350 in to have a remote starter installed. While there I had them install a keyless entry with remote. paid about 300 bucks for it all installed
Old Apr 12, 2004 | 01:12 PM
Kenwood's Avatar
Kenwood
Yes there is a way to tell....I cant remember the exact procedure But You take and put the keys in the ignition and TURN ON OFF ON OFF ON OFF....Its something like 5 or 8 times....If it has the module the doors will unlock.... Thats the correct procedure BUT I just cant remember the number of times to turn it on and off.....
Old Apr 12, 2004 | 03:17 PM
Greg250's Avatar
Greg250
The only way to tell if you have a factory keyless entry is to look and see if you have factory installed door lock/unlock relays. If you don't, then you will have to go with a aftermarket system. I have a Valet keyless entry/remote start in mine and it works quite well. If you do have the door lock/unlock relays then you can go to a ford dealer and see about getting the remote for your truck. Putting a keyless entry in does require some electrical knowledge so if you don't know what you are doing just bring it somewhere to be done.
Old Apr 12, 2004 | 03:18 PM
Greg250's Avatar
Greg250
BTW you can install a keypad on the door very easily. they have ones programmed for you application that run on batterys and attach to the door with sticky tape
Haakeyez50
Apr 1, 2013 09:58 AM
Chrome FX4
2004 - 2008 F150
Apr 13, 2010 09:27 PM
95_4x4_jay
Oct 27, 2005 01:26 PM
Kurious
2004 - 2008 F150
Jul 31, 2005 12:27 PM
71_4x4_390
Sep 9, 2004 10:59 AM
