Funky '02 4x4
>sent "wasted" to this axle shaft and no power will be
>transmitted to the ground until it is locked also.
>This scenario may help also....A few years back I parked my
>96,manual hubs manual transfer case on solid ice and was in
>2wd.at the time.When I left I first locked the hubs and then
>shifted the lever into 4wd.I started the truck and tried to
>pull forward,low and behold it seemed to still be in 2wd.I
>let off the gas and then goosed the throttle a bit the truck
>moved forward slightly and then all of the sudden the front
>wheel(s)started pulling like they were supposed to when in
>4wd.I may be wrong here but I believe the hubs may need to
>see a bit of forward movement from the wheel to initially
>lock when placed on 4wd.That's what I've always assumed
>since the day this happened to me in my 96 model.
4x4x4x4
You are correct,have any of you seen the design of these hubs
they look like a big wratchet with a spring behind it with o-ring seals
to keep the moisture out plus provide the seal for the vacum to draw against.
The manual hubs have a cam which as you turn the selector **** ,it loads the spring to push on the wratchet when the wheel rotates the
wratchet locks in the hub.
My thoughts are you may have a dry (no grease in the hub)or you have
dirt or wear particles within the hub itself which causes sticking.
Or leaky vacum line or o-rings to that hub!
Just my .02
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
