Sponsored by: Real Truck
Cruise control surge
Old May 7, 2002 | 09:24 PM
GRUMPY_ FD's Avatar
GRUMPY_ FD
Old May 7, 2002 | 10:20 PM
NoMo's Avatar
NoMo
Anyone had this fixed yet? If so, what did they do? TIA
Old May 9, 2002 | 12:04 AM
NoMo's Avatar
NoMo
Guess I'm not the only one afraid to have this "fixed".
Old May 9, 2002 | 12:44 AM
dad4dds's Avatar
dad4dds
I'm not sure I understand. I have not had any trouble with my cruise control.
Old May 9, 2002 | 02:12 AM
V10man's Avatar
V10man
The only surge I've had is when going down hill. The cruise can't keep the rpm's steady. It will jump a few hundred then settle down and repeat. Ford replaced the servo. Guess what, it still does it. Been living with it now for yrs.
Old May 9, 2002 | 07:47 AM
benr0's Avatar
benr0
NoMo, I've been to the dealer once about 6 months ago, was told it was a known problem, check back in 30 days for a fix.
I have not went back to check. I just keep it off 70 and it's ok, but I would like to have it fixed as well.
Old May 9, 2002 | 04:57 PM
NoMo's Avatar
NoMo
As benr0 hinted, some of our trucks have a problem when the cruise control is set at about 70mph (± 2mph). A few have also reported a problem around 40mph but I haven't tried to duplicate the problem at that speed yet. Regardless, the problem is that the truck (even on flat land) will surge terribly- like it goes to WOT then it lets off the gas completely. It does this almost constantly as long as speed is set at 70mph. Everything works fine at other speeds. From my experiments, it definitely seems speed related as disengaging OD has no effect on the surge at all.
Old May 10, 2002 | 07:21 AM
codywyk's Avatar
codywyk
Found the following TSB which may address the problem, although they don't describe it as a "surge". My truck has done this a few times at 50 MPH with the CC on. It seems fine at other speeds. Definitely annoying when it happens though - full throttle then not enough throttle like the thing can't make up it's mind.
Make: FORD TRUCK
Model: F SUPER DUTY
Year: 2001
Service Bulletin Number: 14434
Bulletin Sequence Number: 620
Summary Description:
SOME VEHICLES MAY EXHIBIT A BUCK OR JERK (ALSO KNOWN AS HITCHING) DURING HIGHWAY DRIVING AT SPEEDS 40 MPH OR GREATER WITH THE CRUISE CONTROL ENGAGED. *TT
Old Mar 11, 2004 | 08:03 PM
Ranbrg01's Avatar
Ranbrg01
Thumbs up That's what she's doin
I own a 2001 excursion and bucks and surges when the cc is set.
The problem is it only seems to do it when I'm on a trip and the dealer thinks I'm nuts. They can't find anything wrong when it's in the shop.
Next oil change I'll give them this info. Thanks
Old Mar 11, 2004 | 09:18 PM
Tlattin's Avatar
Tlattin
A bunch of guys have solved this by changing out the ABS controller. If it still under warrantee, your dealer should do it pro bono, as there is a TSB for it.
Old Mar 12, 2004 | 12:10 AM
Ranbrg01's Avatar
Ranbrg01
I bought it used last January w/30k and it's done it the hole time but only on trips. The dealer only drives around town and it won't act up on them. But the conplant has been on goin for a year when I still had the factory coverage but I'll see what they say
