Build Date Question?
Old Feb 4, 2004 | 04:07 PM
Paul 33's Avatar
Paul 33
Originally posted by Jim Diesel
Paul 33,
I'm in the Rochester area, what is the name of the good dealer...always looking for good back-up.
Jim, I don't know if it is allowed to list a dealer or not. Since this is only my second post, I was not allowed to e-mail you. send me an E-mail and I'll give you the info.
As far as removal of the CAT, who cares if it voids the exhaust warrenty? The exhaust will last longer than 3y/36k anyways!
If performance is what your looking for, A 4" Exhaust and a chip or programmer are the answer. With the past experiance of Two 2000 7.3 PSD's, the 4"(Banks) exhaust made almost an unnoticeable difference in performance WITHOUT the Chip(+80hp-150#/ft)! BUT it made a HUGE differnce in EGTs. The same chip in the other 2000 7.3, with a 3.5(Banks) Exhaust, ran noticeably higher EGTs(still better than stock).
DO NOT RUN "HOP-UP" CHIPS AND PROGRAMMERS WITHOUT A 4" OR BETTER EXHAUST While pulling a Heavy Load. If you do, you won't for long............
I found the Engine Build date on the top of the Driver side valve cover, all the way to the rear.
Old Feb 5, 2004 | 06:23 AM
Jim Diesel's Avatar
Jim Diesel
Paul,
Tried to send you an email via your profile...says you don't want to receive emails via this forum.
I have seen others use dealer names on the forum before without any chastising, so I'll ASSume there is no problem with it.
Old Feb 5, 2004 | 04:42 PM
Paul 33's Avatar
Paul 33
Orleans Ford Mercury in Medina New York.
I'll have to fix the profile settings!
