Help Me!!!!!!!!!!!!
Old Jan 30, 2004 | 01:54 PM
bearfoot_25's Avatar
bearfoot_25
Unhappy Help Me!!!!!!!!!!!!
I HAVE A DURASPARK II IGNITION SYSTEM. THE OTHER NIGHT I LEFT MY KEY IN THE ON POSITION WHILE B.S. ING WITH A FRIEND,FOR ABOUT AN HOUR. NOW MY TRUCK WILL NOT START!!!!! I REPLACED THE IGNITION BOX ON THE FENDERWELL AND ALSO REPLACED THE DISTRIBUTOR! WHAT ELSE COULD IT BE. I HAVE ALSO CHECKED ALL OF THE SUPPLY WIRES AND EVERYTHING SEEMS TO BE FINE, BUT NO OR VERY LITTLE SPARK WHATSOEVER!!! AND THE TRUCK STILL WONT RUN IT JUST KEEPS TURNIG OVER AND NOR FIRING. ALSO CHECKED FUEL SUPPLY, PLENTY O FUEL!!!! CAN ANYONE HELP ME OUT HERE????
Old Jan 31, 2004 | 10:10 AM
bodyman's Avatar
bodyman
Have you checked the coil output?My 85 Bronc was doing something similiar turns out the switch on the bottom of the steering column wasn't engaging properly,and sometimes it would start and sometimes not. Most of the time it would'nt start when i was in a hurry to go some where!!Imagine that S*#T.
Old Feb 1, 2004 | 08:00 AM
fordnut1985's Avatar
fordnut1985
check the coil with a volt meter and make sure u have 12 volts to the coil with the key on and atleast 9 volts while cranking. if that checks out ok pull the wires of the cap and connect a test light to the positve side of the coil and touch the negetive side with the test light while a buddy cranks the engine over and make sure the test light blinks as he cranks it, that will make sure you are getting a signal from the module.
good luck
Old Feb 1, 2004 | 05:39 PM
prostocktom's Avatar
prostocktom
You might have burned up the solenoid also. You can also get a heavy solenoid to replace it if that the problem. Tom
Old Feb 2, 2004 | 02:35 PM
fordnut74's Avatar
fordnut74
My dad always told me to never leave the key on without the rig running or you would burn up the coil. Not sure if that is true but maybe??
Old Feb 3, 2004 | 06:53 PM
MATHRAM's Avatar
MATHRAM
It did the same thing on my truck I left the key on while I was changing some vacuum hose and my hand touch the coil and it was very hot.I put the key in off position but it was to late my coil was burn.So it true that you can burn your coil!!
jrb412
Nov 5, 2010 03:15 PM
davidhh
Oct 5, 2006 12:14 AM
1987_white_f150
13
Sep 21, 2006 05:30 PM
dani9678
Sep 22, 2004 07:20 PM
brokenrings
Electrical Systems/Wiring
Sep 17, 2003 02:21 PM
