electronic ignition
Old Jan 30, 2004 | 08:38 AM
rarials's Avatar
rarials
electronic ignition
I have installed the duraspark II ignition in my 351C in place of the old points. I am wondering where the best place to hook my hot wire to. I currently have it connected to the starter solinoid at the same place that the battery cable(hot side) hooks up to. Is this right? My battery keeps getting sucked dry. I have to jump my truck off all of the time but my gauge shows that I have a good charge when the trucks running so I'm pretty sure that my altenator is ok. I am going to go buy another battery today and see if maybe I just have a bad battery.
Old Jan 30, 2004 | 12:57 PM
Torque1st's Avatar
Torque1st
Posting Legend
The way you had it hooked up drained the battery. There battery is probably OK unless it froze while drained. A charged battery won't freeze but a discharged one will.
There are two power sources needed for a duraspark module. You need a hot in start and a hot in run. You had it connected to a hot always connection.
Old Jan 30, 2004 | 12:58 PM
bubbaf250's Avatar
bubbaf250
With the DS2 system, there are three "hot" (+12VDC) wires that you need to have connected correctly: main power for DS2 module (red wire), start signal for DS2 module (white wire), and coil primary circuit.
Here's a nice wiring diagram for the DS2 ignition system:
http://www.trailhed.com/images/DuraSpar.jpg
Old Jan 31, 2004 | 12:07 AM
Torque1st's Avatar
Torque1st
Posting Legend
The third is not for the duraspark module itself, it is for the coil, so I did not list it.
Old Feb 6, 2004 | 08:27 AM
rarials's Avatar
rarials
Thanks for all of your help. I now have my box wired up right and no more jump starting. Thanks again.
