Vacumm leak fix
Old Jan 29, 2004 | 06:11 PM
Mic236's Avatar
Mic236
Vacumm leak fix
Has anyone fixed a vacumm leak between the egr tube and upper intake? On a 96 Explore 4.0L. Does this have an O ring Or what? Thanks
Old Jan 29, 2004 | 09:26 PM
ltfox's Avatar
ltfox
Its got an o-ring on it. Never had any trouble with it leaking though.
Old Feb 14, 2004 | 06:31 PM
C.Caskey's Avatar
C.Caskey
How do you know its leaking does it make any noise?I have a 96 Exp XLT 4.0 that makes a whistling sound when you give it gas or get under load. Ive tried everything checked the IAC , went over it with carb cleaner a found nothing, I'm going to replace the O-rings on the upper intake tomorrow and hope that does it. If not maybe the EGR tube ,but it does not sound like its coming from there.
Old Feb 15, 2004 | 04:37 PM
Mic236's Avatar
Mic236
Spray Carb Cleaner where the EGR tube goes into the intake, if you have a vacumm leak there the motor will speed up
Steelhorse
Oct 25, 2015 05:47 PM
backyardfordpart
Feb 16, 2006 08:11 PM
silverselkie56
Feb 13, 2006 03:55 PM
domc
Aug 16, 2004 05:36 AM
CRJ900
Apr 12, 2002 12:01 PM
