EEC Test Connector Location
Old Jan 29, 2004 | 05:40 PM
storminator's Avatar
storminator
Question EEC Test Connector Location
Hi all-
I own a 1995 Ranger 2WD 4.0 XLT. I'm having trouble locating the EEC Test Connector. Anybody know where it lives?
Any help is greatly appreciated!
Eric
Old Jan 29, 2004 | 05:47 PM
BassGuy's Avatar
BassGuy
If you're talking about the jack that you plug the OBDII tester into, on my '96 it's under the steering wheel, to the left of the hood release. It's under a cover, though.
Old Jan 29, 2004 | 09:13 PM
hreed's Avatar
hreed
On my 95 it is under the steering column with a small cover that you can pull off without any tools. It has a small "finger access" for lack of better words. Check the door jamb for the month it was made. If it was before July, a standard scanner will not work. Let me know if you need more info, I have been dealing with this problem for about a year.
Old Jan 30, 2004 | 01:01 AM
storminator
Yup, it was pre July. And that would explain why it doesn't fit. Too bad I can't return it! What are my options?
Thanks for the help-
Eric
Old Jan 30, 2004 | 05:12 PM
hreed's Avatar
hreed
I found a scanner that will work. The Autoxray 2000. Pretty nice tool, but it's $200. However,it has already paid for itself. On the 95 Ranger, you have to set it to read "Generic OBD II".
Old Jan 30, 2004 | 05:51 PM
storminator
Is there any way for me to read the codes without spending $200 on a tool?? I've already spent $40 on one that won't work...
Old Jan 30, 2004 | 08:27 PM
hreed's Avatar
hreed
Try some of the auto parts stores. There are some that will pull the codes. You could try to reset the computer to see if the light will stay off. Disconnect the negative battery terminal for about five minutes. Sometimes the light comes on for a one time problem. If the light does come back on, try disconnecting the various electrical connectors on the sensors and cleaning with a good electrical cleaner. If that doesn't work, you are stuck with pulling the codes. The early 95 is a tough one to find a scanner for. Try to sell the scanner you have. Keep us posted.
txfordcrew
Jan 10, 2015 02:17 PM
bluneon
Aug 14, 2006 03:41 PM
xamack24
May 5, 2004 12:23 PM
jmcdaniel99
Bronco II
Sep 16, 2003 08:46 AM
Memento
1978 - 1996 Big Bronco
Jun 16, 2003 05:54 PM
