84 f-150 brake problem...
Old Jan 29, 2004 | 05:40 PM
84f150guy's Avatar
84f150guy
Usually my brakes catch pretty high, now they're barely catching and they're all the way to floor. Once i put the pedal to the floor, my "brake" light comes on the console above the guages.
I just put a new master cylinder in it..
Any ideas?
Old Jan 29, 2004 | 05:50 PM
86f15035s's Avatar
86f15035s
you have a loss of pressure probably a rear line or wheel cylinder
Old Jan 30, 2004 | 12:39 AM
Superdave's Avatar
Superdave
84f150guy
Make sure your rear shoes are adjusted out properly also. You can't always rely on the auto adjusters to do it for you.
And yes you could have a leak some where else in the system.
Old Jan 30, 2004 | 12:55 AM
torquemeister's Avatar
torquemeister
bad brake booster??
Old Jan 30, 2004 | 03:56 AM
copedipperoh's Avatar
copedipperoh
yeah i just bought an 84 and the brake adjusters were stuck so i took them off heated them up with a orch and adjusted them, then i put them back on and adjusted it and it was fine, and also your brake light may be on because your emergeny brake cable is broken.....at least thats what happened to me.
Old Jan 30, 2004 | 11:58 PM
Superdave's Avatar
Superdave
torquemeister
A bad vacuum booster will just cause a hard pedal.
Old Jan 31, 2004 | 05:19 AM
torquemeister
My friend's '86 brake booster went out, and his pedal was mush all the way to the floor. It also caused his brake light to come on. New booster, and his brakes worked fine. That's my one and only experience with them, so maybe it was an anomaly??
TM
Old Jan 31, 2004 | 04:42 PM
rambo84's Avatar
rambo84
I recently had the same problem on my 84 and it wound up being the driver's side rear wheel cylinder was leaking. Changed it out, re-bled the line and walla! Problem cured.
Old Jan 31, 2004 | 07:39 PM
Wagion's Avatar
Wagion
Always start with the simple stuff
Did you bench bleed the master cyl before putting it on?
Did you bleed ALL four wheels?
Are you loosing brake fluid?
Auto Adjsters working?
Did you get it put back together right?
Old Jan 31, 2004 | 11:11 PM
Superdave's Avatar
Superdave
Wagion
Good answer.
A falling pedal is normally caused by any one of these. It normally is not something all exotic.
I my self have never seen a bad vacuum booster create a falling / fading pedal. It just feels like when your pulling a disabled vehicle without the motor running and you have to stand on the brakes a little harder to get it to stop. Just a hard pedal that requires more effort to stop.
But thats just been my experience.
