1978 - 1996 Big Bronco
bronco problems
Old Jan 29, 2004 | 08:51 AM
mikemotorhead's Avatar
mikemotorhead
bronco problems
I have a 79 bronco with a 351 motor .It is my plow vehicle and is driving me crazy. It will start up and run but sputter and shut off from anywhere 20-45 minutes. It will not restart or run till the next day and the same thing will happen again! The motor also has no power. This seemed to happen gradually over the past 2 years. The motor is tired but always started and ran decent.
Things I have done so far- replaced ignition module, dist. pick up, cap rotor,wires & plugs. Replaced fuel pump,filter ,gas tank and lines.
Can a carb. cause these problems? Thats the next thing I'm going to try! I don't think it is vapor locking cuz it does not overheat. Could it be happening anyhow? Is this a problem with these motors?
Any help would be appreciated before I run this thing over a cliff!
Thanks Mike
Old Jan 29, 2004 | 09:21 AM
73Custom's Avatar
73Custom
Welcome to FTE...
Yes, a carb can cause these problems. Is the choke working properly?
Next time it dies, check for fuel. With engine OFF - look down carb and move throttle. You should see two squirts of fuel into the venturis. If no squirts, then you have a fuel problem.
Also check for spark at coil and plugs.
Let us know what you find. Take it one step at a time...
Marty
Old Jan 29, 2004 | 10:21 AM
mikemotorhead
Thanks Marty,
Forgot to mention that I also replaced the coil and that I have spark at the plugs when it shuts off. Also when it shuts off if I turn the motor over fuel squirts out of the inlet hose. Not sure if the accelerator pump shoots fuel or not.
The choke works sometimes. Could it be any of the old emission garbage not functioning properly or a vacuum leak. Seems if it was that it would not run "OK" for awhile before shutting off? I'm going to replace the carb next and keep my fingers crossed!
Thanks Mike
Derka1
16
Nov 8, 2016 10:53 PM
Nick Gearity
Sep 4, 2016 05:24 PM
winger4647
Mar 20, 2016 10:15 PM
COLEnMICHAELS66
Mar 17, 2006 10:04 PM
little rowe boat
Mar 4, 2006 07:21 PM
