c-6 ????
Old Jan 28, 2004 | 06:14 PM
ClodsFe's Avatar
ClodsFe
c-6 ????
hey fellas- gettin ready to build a 390 and after some posts in that arena I've become stumped. Some say tremec some say richmond and I'm wondering about just a c-6?At this point and time most funds are being used on engine rebuild and chasis reconditioning. Going out and buying a trany from retailer or the like is impossible.I would like to run a 3.50 rear cuz I'll being doing highway travel during hunting season. However with the upgrade I'm doing to the engine I don't want to waste the power. I want to make the kids around here in thier wantabes hang their head in that a older guy in a older truck just smoked 'em. Any suggestions would be welcomed
Thanks
Old Jan 28, 2004 | 09:30 PM
SoCalDesertRider's Avatar
SoCalDesertRider
You didnt say how heavy the truck is or what size tires you're using, but I can tell you this much: The 3.50's in my 6200 lb F350 Crew Cab with 33" tires and a 351/C6 are waaay toooo high. You wont be smoking anybody with those gears. I regularly get tromped on by Honda Civics, Toyota Corollas, even Geos and Hyundais, especially if there is a hill involved. I would at least go with 3.73's, or better yet 4.10's, especially if you're going to tow anything or haul anything heavy like a camper. As far as the transmission, C6 is a good trans and can stand the stress of a big engine and a heavy truck and you can find them anywhere for a reasonable price. Good luck with your project.
Old Jan 28, 2004 | 09:35 PM
wildjon300ci's Avatar
wildjon300ci
Wait, with a 390 that's mildly warmed over, 3.50 gears and a C6 transmission would be fine. My truck is pretty quick with 3.55 gears, a c6, and a warmed over inline 6. Heck, I can chirp the 33" tires from a stop, and with a little brake they light up wth no problem. A 390 should ROAST them from a standstill wth that setup.
Old Feb 1, 2004 | 06:16 AM
ClodsFe's Avatar
ClodsFe
Dissision made-c-6;tci perf. master kit;jet high po. servo unit; b&m shift kit (if tci's is not enough) ; tci 2000 stall; b&m mega truck shifter; brute force u-joints; balanced drive shaft;3.70 9 inch rear with LT265/75 r 15's. Truck is 65 f100 swb. engine is- 390 blueprinted and balanced 30 over; sealedpro pistons @ 9.5:1 comp. with heads milled to get comp. up to 10.5:1/hsot peened and dressed beams/2.09 in 1.70 exhaust, ported and bowl cutwith a 3 angle valve job, and port matched to intake and exhaust. headers. performer rpm intake and performer rpm cam(572.list)swirl stepped 1 in. spacer 750 edel. carb/ adjustable valve train. degreed cam and crank. pertronix ignitor 2 and flame thrower coil; splitfire plugs(indexed)and splitfire wires.K&N breather with breather top plate-
Would it be safe to say " Get in, sit down, shut up and hold on ??????
PLease advise. Thanks fellas
Fabian Ramirez
Dec 18, 2016 07:16 PM
Flip-150
Jul 16, 2016 04:04 PM
PsycoJuana
Jan 18, 2016 02:46 PM
artieb
Nov 26, 2015 10:32 PM
mikeberman04
1978 - 1996 Big Bronco
17
Apr 9, 2010 09:02 PM
