oxygen sensor removal
Old Jan 28, 2004 | 05:38 PM
torquemeister's Avatar
torquemeister
Anybody have any tricks for removing the oxygen sensor? All I've managed to do so far is snap the wire, but the exhaust manifold is in the way of being able to get any kind of wrench on it to get it out.
TM
Old Feb 10, 2004 | 01:13 PM
Bronco86's Avatar
Bronco86
if you haven't got it out yet you can get a special tool from auto parts stores
Old Feb 10, 2004 | 01:39 PM
f100guy's Avatar
f100guy
heat it up with a torch first to make it easier
Old Feb 10, 2004 | 03:38 PM
bremen242's Avatar
bremen242
Use some pb blaster and leave it soak for a while
Old Feb 11, 2004 | 12:54 AM
Ol Rudy's Avatar
Ol Rudy
Which vehicle?
If you heat the manifold area, it will expand slightly so oxy sensor will be easier to remove. Heat the sensor and IT will expand...making it tighter.
Penetrating oil an excellent idea....be patient...overnight a good idea. (there are stronger penetrants than WD40..ask your parts shop.)
When you install the new one, make sure to coat the threads with "Anti-Seize" (brand) compound available at auto and farm stores . Had that been done by previous installer...it would have been removable without all the extra work.
Old Feb 11, 2004 | 04:12 AM
torquemeister
Actually, a friend at work had the special socket that is big enough to fit over the sensor. Much easier than crescent or open-ended wrenches! I guess 90% of it is having the right tool for the job at hand.
TM
Old Feb 11, 2004 | 04:58 AM
bigric's Avatar
bigric
The 02 socket is a deep 7/8" socket with a notch in one side to allow for the wire. Anything 7/8" that you can fit in there should get it out.
Old Feb 11, 2004 | 06:38 AM
bremen242's Avatar
bremen242
Just a side note:
those 'special' sockets with the groove in the side are only good for installing the sensor. If you use them to remove it, they flex and want to slip if the sensor is tight.
As bigric said, cut the wire off, and use a regular deepwell 7/8" socket.
also, when you anti-seize it, make sure you get high temperature conductive anti-seize. If it is not conductive, the O2 sensor will not ground on the manifold and will give bad reading, or not work at all.
Old Feb 11, 2004 | 07:13 AM
wtroger's Avatar
wtroger
Every oxygen sensor I have changed, the new one comes with the anti-seize on it.
Old Feb 11, 2004 | 09:10 AM
Ol Rudy's Avatar
Ol Rudy
I wonder how many installers clean the new sensor thinking the compound was just for "preservation" while on the dealer shelf. I would bet many.
Well, it looks like this job may be completed with use of the right tools....as is usually the case.
Hope everything goes well.
Old Feb 11, 2004 | 03:55 PM
bremen242's Avatar
bremen242
wtroger: Every bosch O2 I've seen (the only ones I generally get because the is whats in stock) has the stuff on it. I've used a couple factory ACDELCO that don't. I don't know if Ford motorsport puts it on or not.
