Heater Door Blend Problem
Old Jan 28, 2004 | 02:49 PM
rangerford's Avatar
rangerford
Unhappy Heater Door Blend Problem
1998 Ranger 4x4 Super Cab 3.0 v6
I just bought this truck and apperently have many of the typical problems. I have worked through most of them on my own and with help but now my heater is blowing some warm air no matter where the temp dial is set. Dial is ok not cracked, if I fold down the glovebox I can hear the acctuator working? A friend who is a mechanic said that dealer charges lots of $$$ for the fix depending on a cracked plenum(approx 10hrs labor to remove dash) or door blend. My friend said he knew a guy that would use a 2" hole saw to remove enough plenum plastic to work on the problem to fix then just place the plastic piece drilled out back in. Should I do this?
Old Jan 28, 2004 | 03:24 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
Go to the tech info post at the top of the page, there's a link there on the fix.
Old Feb 2, 2004 | 12:37 PM
rangerford's Avatar
rangerford
Just wanted to thank all those involved with the thread on the heater door blend fix. My problem was exactly as stated in the fix I did it myself and saved lots of $$$ Thanks again.
Old Feb 2, 2004 | 04:05 PM
Rockledge's Avatar
Rockledge
Glad to hear it.
