400 for mud???
Old Feb 7, 2004 | 12:37 AM
Brian S's Avatar
Brian S
A belt drive would be my 1st pick
Unfortunately the retrofit kits are expensive.
Old Feb 7, 2004 | 09:40 PM
There Goes The Neighborhood's Avatar
Originally posted by monsterbaby
what do you mean that gear drives cause erratic timing that is the one major advantage of the gear drive the timing is rock solid compared to ANY timing chain as ALL of the timing chains stretch, and usually some within the time that it takes to break in the cam, and will allow atleast 1 degree of cam timing change, and the cheaper rollors will alow as much as 3 deg ( I measured a summit chain in a 302 when I changed a cam to go bigger, the motor had less than 100 miles on it, and allowed 3 deg of cam change)
Apparently, you havn't got a good brand of chain, because anything worth buying does not stretch. What I meant about the timing being erratic, is that a chain will dampen harmonic vibrations, where as a gear drive will not. This transfers directly to the cam and distributor, causing erratic timing.
Old Feb 8, 2004 | 08:33 PM
crossbeed_65's Avatar
crossbeed_65
Wow. I was not aware of that. I guess I will reconsider the gear drive and go for a good timing chain. What are the better brands out there?
Old Feb 9, 2004 | 01:57 AM
kopfenjager's Avatar
kopfenjager
Arent most timing chains made by the same company?
Old Feb 9, 2004 | 11:24 AM
Some of the better brands include Ford Motorsport, Cloyes, and DynaGear. If I am not mistaken, you are correct, all are made by DynaGear. Make sure to get a double roller, as these are much better than a factory replacement set.
Old Feb 9, 2004 | 12:32 PM
monsterbaby's Avatar
monsterbaby
As a point of reference on my chain, it was a summit chain which is also made by dyna gear, and it was double roller but ALL chains stretch it is the nature of the beast, mine just stretched faster possible than other as I abuse this motor hard but take any motor with any timing chain, and measure how much cam timing change you can get without turning the crank you will be suprised
Old Feb 9, 2004 | 05:42 PM
On the 400, 0 stretch, and on the big block minimal, and this was run on a motor previously.
pound727puppy
1978 - 1996 Big Bronco
Apr 7, 2010 11:18 PM
GLC79150
Feb 8, 2008 04:18 PM
dimora
Apr 21, 2004 09:17 PM
mtyrell
Apr 29, 2003 10:15 PM
Powderthumb
Jun 2, 2002 01:10 PM
