piston?
Old Jan 28, 2004 | 07:58 AM
lincoln's Avatar
lincoln
Question piston?
hi there
got a question about pistons
i have a std. D1VE 460 block which is not decked and a pair of std. C8 heads which are not milled.
now is my question which piston i have to choose to get a comp ratio +/- 10,5 :1 ????..
hope somebody can help me
greetz from holland
Old Jan 28, 2004 | 08:30 PM
nightravin13's Avatar
nightravin13
try the speed pro flat topped pistons.
Old Jan 28, 2004 | 10:48 PM
airharley's Avatar
airharley
You can look them up on summitracing.com and it will tell you the final compression ratio with your 72cc heads. They have a bunch of different piston makers and so on to give you an idea. Or if your still confused call the tech help line for more info. They actually help you out even if you haven't bought anything from them, they want your buisness. LOL Or you can go to the tech article section and down load the Compression ratio simulator to give a better understanding. Scroll all the way to the bottom of the page to find it. Plus there are a few other helpful calculators in there as well.
