Offroad & 4x4
How do autolocking hubs work?
Old Jan 28, 2004 | 07:14 AM
WookieWebster's Avatar
WookieWebster
Hey all,
I have a 96 F150 with a dana 44 and IFS. The transfer case engages when I hit the button and the front driveshaft turns, but the power doesn't make it to the front wheels from there. The front axles turn a bit, but can be stopped easily if I apply pressure. I don't know enough about how the auto-locking hubs work to know where/what to trouble shoot from here. I need some direction before I start ripping thing apart. It seems like the failure would have to be either in the diff or the hubs. Any ideas?
Thanks
Old Jan 28, 2004 | 07:38 AM
85351ho's Avatar
85351ho
they r torque sensitive in that era of trucks.....they sucked
when the axles rotate, they are supposed to engage, yours are either sticking or just broke
Old Jan 28, 2004 | 09:39 AM
WookieWebster
So, when unlocked, the front axles just "float" unattached (they don't turn). Is that right? So what provides the torgue to get the hubs to lock, the diff fluid?
Old Jan 28, 2004 | 09:51 AM
No_BS's Avatar
No_BS
The axles turn, and that locks the hubs. Don't worry about it and get manual locking hubs, never have this problem again.
Old Jan 28, 2004 | 10:05 AM
WookieWebster
So you are saying that the front axles are always connected into the power of the front driveshaft at the diff? Then I have bigger problems than what manual hubs would fix, because I can grab the front axle and it stops turning while driveshaft is still going. What could be broken in the differential?
Old Jan 28, 2004 | 10:38 AM
fishmanndotcom's Avatar
fishmanndotcom
i'm curious to know....how did you test all of what you said? you put it on jackstands and put it in gear or something?
i'm with BS....get some manual hubs, that way you won't have any problems in the future. also it would prolly fix your current problem!
-jason-
Old Jan 28, 2004 | 10:43 AM
WookieWebster
Yep. Very carefully.
Old Jan 28, 2004 | 10:56 AM
fishmanndotcom
lol sounds like me....what exactly are you applying pressure to? if you hold one tire will the other spin? have you tried tapping the caps of the auto hubs with a rubber hammer or something to get them to unstick if they are stuck?
-jason-
Old Jan 28, 2004 | 11:28 AM
WookieWebster
I am applying pressure to the front axle shafts (either) and they stop moving. There is no tire movement of any kind on either side (in the front).
This truck is relatively new to me and the previous owner was a traveling sales person who never off-roaded at all. I thought maybe the hubs might be frozen and I wanted to tear the whole thing apart and maybe replace the front bearings while I was at it, but I was not sure. I need to know how it is supposed to act in the unlocked conditon first, to determine how much work this is going to be.
Old Jan 28, 2004 | 11:31 AM
fishmanndotcom
it's not a lot of work at all....i can do a set of hubs and bearings in 30 minutes. with your truck in 4x4, transmission in neutral, and front hubs locked.....can you turn youjr front d/s? if it is so easy does both tires turn? or just one?
do your caps have 3 or 5 torx head screws holding them on?
-jason-
Old Jan 28, 2004 | 12:44 PM
85351ho's Avatar
85351ho
when you engage the 4x4, the front driveshaft turns, which spins the axles, which puts torque to the hubs, that supposed to lock them, yours are stuck or broke......now since they aint locking you have no power to the wheels
the reason you can be spinning the front d-shaft..grap one axle and make is stop, is because your front has an open diff, try and stop both axle shafts and see what happens....all you need to do to make it right is slap some manual hubs on there
and yes, at least one of the front axles will always turn when the driveshaft is spinning(unless something is broke)
i hope that made some sense? cause i can go into more detail if you like
Old Jan 28, 2004 | 01:13 PM
WookieWebster
I need to make this clearer. When the front driveshaft is turning, BOTH front axles are stopped at the same time. I know that I don't have a LS front diff and I expected that if I stopped one the other one would turn, but that is NOT happening. The hubs are not locked at this point (obviously, since they are not manual).
Does this mean that something in the front diff is broken?
BTW thanks for all the help
Old Jan 28, 2004 | 05:19 PM
kopfenjager's Avatar
kopfenjager
ugh. yeah dude there is something wrong there.
Old Jan 28, 2004 | 08:48 PM
No_BS's Avatar
No_BS
Well if neither shaft is spinning, and the driveshaft is, it sounds like the diff is shot. Unless, hold on do the shafts spin when you don't have something stopping them? If not, it sounds like a grenaded diff.
Old Jan 28, 2004 | 09:08 PM
fordman300's Avatar
fordman300
didnt they start using vacume motors to run the hubs and such in 96
