Sponsored by: Real Truck
auto 4 wheeldrive
Old May 28, 2002 | 09:10 PM
FortyFords's Avatar
FortyFords
auto 4 wheeldrive
Old May 29, 2002 | 01:23 PM
hbrspringhill's Avatar
hbrspringhill
auto 4 wheeldrive
If I am not able to engage the auto 4 x 4, but it works with the hubs locked, does this sound like a vacum hose problem, and is this a common problem. The truck is 2000 f250 xlt
Old May 29, 2002 | 01:34 PM
Monsta's Avatar
Monsta
Sit. Stay.
auto 4 wheeldrive
Common? Yes and no. It's a common complaint on the board but with the thousands of SD/Exs out there I wonder what the true ratio is.
It is more than likely the vacuum seal within the hub. I say that because I tend to look for the simpliest, most inexpensive fix first. You problem could be worse.
Are you under warranty?
Old May 29, 2002 | 02:23 PM
hbrspringhill
auto 4 wheeldrive
the light on the dash comes on and the manual hubs work, still sound like a vacum line?
Old May 29, 2002 | 03:05 PM
NoMo's Avatar
NoMo
auto 4 wheeldrive
It's most likely either the line or the hub seal. Those are the two most common sources of ESOF problems. Check the hoses going down to the hubs and make sure they aren't cracked, broken, or just disconnected. If they look OK, pull one off and have a helper engage 4x4. When they do this, you should feel a vacuum pulse. If so, then the hub seal(s) are faulty. If you don't feel a quick suction, then the problem is further "upstream".
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
