Mileage Cam
Old Jan 27, 2004 | 04:20 PM
kopfenjager's Avatar
kopfenjager
Question Mileage Cam
Just wondering if anyone knows of a cam that gets good gas mileage out of a 400?
Old Jan 27, 2004 | 05:27 PM
Torque1st's Avatar
Torque1st
Posting Legend
255DEH
Old Jan 27, 2004 | 05:28 PM
F150daniel's Avatar
F150daniel
stright up timing chain
compcams 255DEH cam
new valve springs
Old Jan 27, 2004 | 05:37 PM
scroob's Avatar
scroob
How does the 255DEH compare to the stock cam for torque? I get 17.5 MPG with the stock cam.
Old Jan 27, 2004 | 06:11 PM
kopfenjager
17.5 WoW!!
what else do you run to get that kind of mileage?
Old Jan 27, 2004 | 11:39 PM
Matts72's Avatar
Matts72
I get 16-18 MPG, depending on how heavy the foot is.
Mine is stock, with high performance coil, wires, plugs, cap, rotor, properly tuned 2150, WIX filters, and such.
Old Jan 28, 2004 | 08:32 AM
F150daniel's Avatar
F150daniel
my buddy get 16/19 from his 77 F250 4sp
Old Jan 28, 2004 | 04:17 PM
kopfenjager
WoW! It seems I have some mpg hiding in my engine, now how do I unleash them? Hummmm?
Old Jan 28, 2004 | 05:57 PM
Matts72's Avatar
Matts72
I'd start by reducing your tire size, you are lugging the motor pretty hard turning all that tire.
A good tune up, and a carb rebuild (if necessary), will help.
Old Jan 29, 2004 | 05:09 PM
scroob's Avatar
scroob
Mine's a '71 400 in a Galaxie with 3.00 gears. The original owner said it got 20 MPG when the gas was better.
Old Jan 29, 2004 | 08:43 PM
kopfenjager
Yeah those 35x15.5x15 swampers are my mud tires, the 33's are my street tires. My mileage is about 12mpg with the 33's. My carb needs to be rejetted, I can smell gas in the exhaust. Can that cause my lousey gas mileage? I think my cam is the mager player, its a 268/218 comp cam. I want to switch to a better gas saving cam. Sorry for the long post
Old Jan 29, 2004 | 11:14 PM
Matts72's Avatar
Matts72
Kopfenjager, don't apologize for giving details, , we need em'.
Yeah rejetting the carb should be a priority, you are throwing raw gas down the pipe if you can smell it.
I'm probably out on a limb here, but is your thermactor system enabled?
Old Jan 30, 2004 | 02:13 PM
kopfenjager
no, all the emmission are un hooked
Old Jan 30, 2004 | 04:12 PM
Matts72's Avatar
Matts72
At the very least, I would hook up the PCV system.
I'm not sure what else you can do.
I'm sure you are running headers and free flowing exhaust.
Old Jan 30, 2004 | 05:58 PM
kopfenjager
Yeah headers to 2.5 turbo mufflers that dump under the cab. The pvc is hooked up. New cam is what I need, but what one?
