Bronco II Ford Bronco II
Electrical problem
Old Jan 26, 2004 | 06:29 PM
Mklbcdrp8's Avatar
Mklbcdrp8
Electrical problem
I have a 1990 BII eddie bauer. When i turn the key it just clicks once. I have replaced the cables, sylenoid, starter, and battery and i dont know what else to try. If you have any suggestions please help. Thank you very much
Old Jan 26, 2004 | 07:18 PM
87 XLT's Avatar
87 XLT
Can you pop the clutch & start it? Are you sure the battery is good? If you can pop the clutch or jump start it check the the voltage across the battery, should be about 14 volts.
Old Jan 26, 2004 | 07:24 PM
wolffpax's Avatar
wolffpax
Try checking the hot wire attached to the starter.The bolt sometimes works it self loose not making contact with the starter. While you are down there, look for corrosin at that terminal. The exccess corrosion will cause such a large amount of resistance, it will not turn the starter at all.
OrangeDonkey
Mar 8, 2017 03:58 PM
Z7Hunter
2009 - 2014 F150
Dec 18, 2016 06:58 PM
WolfFox
Nov 18, 2016 04:42 PM
jonrjen
6.7L Power Stroke Diesel
Dec 31, 2014 04:02 PM
5 Star Tuning
South Carolina Chapter
13
Nov 12, 2008 10:44 AM
